Add a fieldname instead of value in calculate field using Python
1823
02-10-2021 01:41 PM
LakshmiSankaran
I am trying to convert this VB script in a model from ArcMap (10.7.1) to a model in ArcGIS Pro (3.7).
Calculating a field ADD1, and  using values from a field ADD2:
Dim MainAddress
If Not [ADD1]= "" Then
MainAddress = MainAddress
Else
MainAddress = [ADD2]
End if
______
I attempted this in the ArcGIS Pro codeblock: and was unable to replace the value with the fields ADD1 or ADD2, so tried a text value instead to see if the logic at least was correct.
Runs as below, but how do I replace the value with values from another field?
def replace(mainaddress):
if (mainaddress != ""):
value = '5'
elif (mainaddress == ""):
value = '99'
return value
I have written the alternate select by attributes -> calculate, but I have a bunch of fields that need this kind of calculation.
Arcade solution welcome as an alternative..
Lakshmi
DavinWalker2
I hope the below helps.
This will replace the field I'm running the calculate field on with the value from the CODE field if the PLANT_ AREA field is not empty and replace it with the vale from field MEAN_AREA if it is empty.
DanPatterson
MVP Esteemed Contributor
Code formatting ... the Community Version - GeoNet, The Esri Community
        value = '5'
        value = '99'
    return value
Now... mainaddress can't be your field name, it can be a variable.
See the examples in this topic
Calculate Field (Data Management)—ArcGIS Pro | Documentation
so
my_code = """
        value = '5'
        value = '99'
    return value
... sort of retired...
DavinWalker2
LakshmiSankaran
Thank you!
Lakshmi
DavinWalker2
You welcome.
