Hi @CordulaGöke!
As we note in the ArcGIS Ideas Submission Guidelines, performance issues are not a good fit for Idea Exchanges. Just like with bugs, performance issues should always be reported to Technical Support for further investigation.
Thank you for being an active member of Esri Community!
@ValeriaChavezContacting technical support seldom leads to anything. With our setup our first technical support contact is the local distributor. Especially the case that opening them is slow, what are they supposed to do about it? It is not that they are not working, so I don't think it qualifies as a bug and the other option to workaround it is just not have notebooks in the project.
