Restore the ability of ArcGIS Pro to resize multiple table fields in one step.
This is a new BUG introduced at ArcGIS Pro 3.X.
Current version: 3.0.2
ArcMap X.X and ArcGIS Pro up to 2.9 and nearly all other apps have the following behavior.
When you select multiple fields in a table, if you then resize one of the fields in the selection, then all of the selected fields will then be resized to the same width as the adjusted field, or if you double-click between two fields then all of the selected fields will adjust to best fit the width of the field contents. This makes it possible to resize a whole table with a few mouse clicks.
Before resize, all fields wide:
After resize, all selected fields adjusted: CORRECT
ArcGIS Pro 3.X breaks this behavior.
Now, at 3.X if you select multiple fields and resize one of the fields in the selection, Pro only resizes that one field and fails to resize the other selected fields. So, if you have a table with many fields, it can be very, very tedious and time-consuming to resize them appropriately.
After resize, only one selected field adjusted: WRONG
