Create New Version - add the Parent Database name to the UI
1345
05-20-2016 08:35 AM
Status: Closed
ThomasBennett1
On the ArcMap Versioning toolbar - the Create New Version Toolbar doesn't indicate the database name when you are Creating a New Version. If you have feature classes from multiple databases in your MXD  the Parent Version pulldown menu just says "sde.default" and or "dbo.default" for all the databases and there is no way to know which parent table is which.  There is also no consistent behaviour between the which layer/feature class you have selected in the table of contents and which parent version is on the top of the pulldown list.  So you have to guess which one you actually have selected and then confirm once you have already created the version that you created it from the parent table you intended.
Suggestion is to add the table name into the Parent Version pulldown, or if text layout space is too limiting, then add a second pulldown menu for the Database Connection.
2 Comments
ThomasBennett1
Forgot my screenshot example...
0EME0000000PjgZ
SSWoodward
Status changed to: Closed
This idea has been closed as a duplicate of the Data Management Idea linked below. Don't worry, you can still show your support by commenting and adding kudos to the open idea. Thanks for your contributions!
https://community.esri.com/t5/data-management-ideas/create-new-version-add-the-parent-database-name-...
