Is there a way to upload a table with COGO Bearings and Distance into ArcPro's traverse tool?
838
06-05-2024 12:58 PM
JayHanson
Sorry if this is the wrong group to posts this question.
anna_garrett
there isn't a super easy way to do it as far as i know.
you can, however, go to your point of commencement/point of beginning, start sketching the first couple of calls, then click the three line menu and export that traverse to a text file. you can then copy/paste your calls as long as you format them similarly. save the text file after you're done. clear the calls you just entered, then load the traverse text file the same way you exported it.
it will be easier if your text editor has line numbers, as Pro will spit out an error on line xyz for any calls that don't work.
AmirBar-Maor
@JayHanson
This is the correct place for your question!
@anna_garrett  is correct - such capability does not currently exist.
Can you elaborate:
  1. Where/how the table is generated?
  2. What format (CSV, Excel...)?
  3. Could you attach an example?
  4.  Does it also specify the POB or commencement point?
You are also welcome to submit an idea on the parcel fabric ideas board.
@TimHodson - FYI
