Why can't I change supportsApplyEditsWithGlobalIds to true?
1314
04-21-2022 06:39 AM
Labels (3)
SSMGroup
I've shared a file geodataset to ArcGIS Online as a hosted feature.  The hosted feature layer includes a point layer with a related table.  The table is used to store inspections.  In survey123 connect, I created a form which will populate to the related table.  This is a process I've done many times before without issue.
When I try to publish the survey123 form, it says "supportsApplyEditsWithGlobalIds must be true."  Sync it on, editing is on, there is a global ID field.  Yet it continues to give me this error.
I've followed all the steps in this technical article to fix the error.  Yet it persists.
I need some guidance ASAP, any help is greatly appreciated.
SSMGroup
It randomly started working again.
SSMGroup
