I've shared a file geodataset to ArcGIS Online as a hosted feature. The hosted feature layer includes a point layer with a related table. The table is used to store inspections. In survey123 connect, I created a form which will populate to the related table. This is a process I've done many times before without issue.
When I try to publish the survey123 form, it says "supportsApplyEditsWithGlobalIds must be true." Sync it on, editing is on, there is a global ID field. Yet it continues to give me this error.
I've followed all the steps in this technical article to fix the error. Yet it persists.
I need some guidance ASAP, any help is greatly appreciated.
