I created a Web Map with two different infographics displaying the number of votes per political party/candidate. These numbers will need to be updated every ten minutes or so, and I tested out whether "Update Data"/"Append data to layer" would properly update the data inside the infographics. It did something very strange - instead of displaying the proper numbers in the updated table, it multiplied the values! I have appended the table multiple times now but, it keeps multiplying the values - in this instance, multiplying the number of votes.
I want to be able to click the box "Update existing features" but it is grayed out. I have unique IDs in my Excel sheet but for some reason, it does not show in the Feature Layer table.
Has anyone ever experienced something like this before?
Please see screenshots below for reference.
Thank you,
Jenny
I got a warning that you do not have private messages enabled. If you go to your profile settings > preferences > toggle the drop-down to private messenger > you can turn this functionality on if you wish. Here is what I would have sent via a DM:
Testing:
Suggestions:
I hope this helps, let me know how it goes.
-Peter
@Anonymous User,
For some reason Private Messenger isn't an option in my settings.
Thank you for looking in to this. I have now disabled Keep track of created and updated features in both the hosted view layers and the hosted layer itself. However, Update existing features is still greyed out in the Append Data window.
Hi @DataOfficer - thanks for changing this setting. Cloning the item I can confirm that the service change tracking setting is no longer there, which is good.
On the cloned service, I am also given the opportunity to append with updating features and selecting the Ref_UniqueID field as the unique identifier. However this hangs and does not complete. The oddity with the unique IDs mentioned above when republishing from FGDB (the error message that they are not unique) was added to when I downloaded the hosted feature layer as a CSV; it only exports about 1/4 of the records. However when I publish this subset as a hosted feature layer, I can append with update features and use the Ref_UniqueID field as the unique identifier.
Would it be possible to add to the Online group or send to pklingman@esri.com a source copy of the data that hasn't been published to Online as a hosted feature layer? I want to take the existing service out of the picture and try a test workflow start-to-finish with the data.
Thanks for your help and patience on this one,
-Peter
