Trying to add a GeoServer WMS to ArcGIS Online
11418
14
09-12-2011 09:11 AM
AledaFreeman
Can anyone explain why this doesn't work?  I'm in arcgis.com trying to "Add Layer from web" with 'OGC Web Service (WMS)"
http://giswebservices.massgis.state.ma.us/geoserver/wms
Do I have the correct syntax?
Here is our GetCapabilities:
http://giswebservices.massgis.state.ma.us/geoserver/wms?service=WMS&request=GetCapabilities
We do have a large number of layers and support a large number of projections.
Is there a way to specify one layer to be added?  What would be the correct syntax for that?
Reply
MikeMinami
Notable Contributor
I think you need to implement CORS support on your WMS server, if this is your server. Because the request are going over HTTPS, the browser (I tested chrome and firefox) is blocking the request to get the popup information.
Here's the error I see.
Load denied by X-Frame-Options: https://walrus.wr.usgs.gov/namss/wms?SERVICE=WMS&REQUEST=GetFeatureInfo&FORMAT=image/png&TRANSPARENT... does not permit cross-origin framing.
Once CORS is supported, you will need to configure this server as a trusted server on the My Organization tab. Click Edit Settings, click the Security tab and enter "https://walrus.wr.usgs.gov" as a trusted server.
Hope this helps,
Mike
JacobMaggard
Occasional Contributor II
Thanks!
Reply
VadimShavrin
Hello, dear colleagues!
I have the same problem. I tried to paste wms (from geoserver) to AGOL. Actually I did it, but the problem is that it cannot be displayed in the AGOL viewer.
The address is:
https://www.landhunter.ru/gs/?SERVICE=WMS&REQUEST=GetCapabilities
in geoserver this link looks like:
http://localhost:8080/geoserver/ows?service=wms&version=1.3.0&request=GetCapabilities
Does anybody have any idea on this issue. I appreciate every answer. The pic from AGOL is enclosed.
With kind regards,
Vadim,
Reply
SebastienPetit
I tried and have the same thing than you.
List of layer but nothing displayed in arcgis.com
Same with ArcGIS Desktop and Gaïa (The Carbon Project - Innovative Geosocial Solutions )-
I think your server is not configured and return something like localhots.... and not the domain name.
Meaning the image is not arriving.
When you check GeoServer Web Map Service  you can see that the returned info go to localhost
Reply
MichaelGinzburg
I can  add WMS service from geoserver. I have popups. But the service ifo is not displaye in the data table widget. What can be the reason?
Reply
