Tracker For ArcGIS
863
04-03-2019 04:34 AM
OmerBen-Asher
I am trying to use tracker for arcgis. I am getting this massege (ATTACHED).
How can I use it with arcgis online?
Thank you.
CraigGillgrass
Omer,
Thanks for your question on Tracker for ArcGIS.  Tracker is currently available for Enterprise 10.7.  Online will be available in late June.
The iOS and Android mobile apps are pending release to the relevant stores and should be available within the week.
You can access our EA site using this URL; https://earlyadopter.esri.com/key/LocationTracking.  You can also view the doc for Tracker which is available here: https://doc.arcgis.com/en/tracker/help/configure-location-tracking.htm
If you have other questions or run into problems, let us know.
Tracker for ArcGIS team
tracker4arcgis@esri.com
DerekLaw
Esri Esteemed Contributor
Hi Omer,
Please see this updated blog by Jeff Shaner,
Location Tracking is coming to ArcGIS Online
Hope this helps,
