Publishing from ArcMap to ArcGIS online
4973
08-02-2015 09:27 PM
RusselQuan
How do you publish to ArcGIS online from ArcMap?
I have an MXD that would like to publish online so I can share it.  I assume that I add the ArcGIS Online in the "Add ArcGIS Server" dialog in the Catalog, but I can't figure out the URL.
Am I on the right track?
Tags (1)
JayantaPoddar
Hi Russel,
You can go to File > Sign In to sign-in to your AGOL organizational account.
Then, File > Share as > Service. Add the AGOL account and necessary capabilities. Publish.
Think Location
JayantaPoddar
Hi Russel,
Think Location
BenGrod
Hi Russel,
Jayanta's steps are perfect, his posting is correct. Couple screen shots below to help spell it out, hope this helps and good luck.
Sign in to ArcGIS Online via ArcMap
Once signed in choose "Share As" from the same menu and select "My Hosted Services" to publish the content of your MXD to ArcGIS Online.
RusselQuan
That was easy!  I need to work through the Errors and Warnings but I now have a clear runway ahead.
Thank you Jayanta and Ben.
