I installed 10.2.2 and need the 'mgisdata' folder to complete my homework. I searched my computer and cannot find it, any idea where it could be?
9008
13
01-12-2017 01:23 PM
AustinBonney
I just now installed ArcGIS 10.2.2 for class and the very first exercise requires the data from the 'mgisdata' folder, but I can't find it. I downloaded the ArcTutor data folder, but it is not there either. Where should I look, or how should I get it?
by Anonymous User
Not applicable
I went down to our Esri Library and checked out the 5th edition of "Mastering GIS" it comes with a disc in the back of the book. I am suspecting the data is on there. If you have newer edition its possible they might state a location where you can download the data in question. If your edition of the book has a preface then there might be a section there detailing how to install the data.
This book is not published by Esri so it is unlikely you would find the data you are looking for on our site.
DanPatterson_Retired
unless you paid attention during the installation process, I would check your c:\users.... folder probably buried somewhere in there
did you do a search using 'mgisdata' in File Explorer
AustinBonney
I paid attention to all the instructions I was given. Do you know what downloadable package the mgisdata folder comes in? Maybe I can redownload it, or maybe the name of that .zip was never provided for me in my instructions. I believe the only data I was told to download was the GISTutor folder.
JayJohnson2
ArcGIS Tutorial Data for Desktop is on the installation DVD, and also in the Downloads section of myESRI.  https://my.esri.com/downloads/
You may have to ask your primary maintenance contact at your organization for access to the download area of myESRI.
AustinBonney
I have the ESRI Tutoring data, but I'll have a look at that list. Thank you!
by Anonymous User
Not applicable
I did a full search on my machine which also has ArcTutor data and it did not return any folder with the name mgisdata. Is it possible that perhaps mgisdata is some data that may have been provided by your professor?
AustinBonney
I am using the book 'Mastering GIS by Maribeth Price' and at the end of chapter one, there are exercises that require me import data from the mgisdata folder. Example: Add Connections -> Click the Look In drop down -> mgisdata -> Oregon...
I don't think my professor provides it. I'll keep looking. I'm wondering if it will be found in another downloadable extension like ArcTutor.
EDIT: On the top of the page (42) it says "Use ArcMap and the mgisdata/Usa folder to answer the following questions..."
by Anonymous User
Not applicable
AustinBonney
You're probably right. Thank you very much. My textbook is used and does not have that, but I'll get right on the case. Thank you!
by Anonymous User
Not applicable
Happy to help!
