I keep changing the GDB, then republishing the service, but the Domains never seem to respect the order change. The field wants the drop downs grouped and I can find no way to make it happen.
I tried to change the GDB and republish - nope.
I tried rebuilding the entire map - nope.
I tried editing the service definition - nope.
Plus in the domain interface you cannot reorder you must retype them all in.
How can I get the order to be what I want?
Hi Doug,
Thanks for the post on this - I was able to reorder domains at this endpoint: https://services<#>.arcgis.com/<OrgID>/ArcGIS/rest/admin/services/<serviceName>/FeatureServer/0/upda..., modifying the steps here to reorder the domains instead of adding a new one: How To: Add coded value domains to a hosted feature service from a REST endpoint
Hope this helps,
-Peter
Did you ever find out the solution for this? I have to manually re-arrange the list by going to ArcGIS online -- layer -- data tab -- fields then dragging domains here. This isn't too painful, but when you found out there's 50+ to do this for I am hoping to find a way prevent this going forward. I even updated to latest Pro but still has this issue 4 years later.
Thanks!
I'm not sure if this is what you're looking for, but I think you can click the domain description header to sort it alphabetically, then check the "Save sorted order?" checkbox.
I remember there being some surprising limitations to that functionality, so keep an eye out for weird stuff.
Such as: Domains View — Indicate that saving sorting only applies to sorting the descriptions, not the codes
