Configuring an App in ArcGIS Online (Public)
6009
11
07-10-2016 12:50 PM
deleted-user-W17i9rKaOdiH
I created a web app from a template that I would like to edit. However, when I go to the application details for the app and then select configure app, it takes me to the configure screen but it never opens. The blue vertical dashes just keep flashing over and over again like the screen shot shows below and all options are greyed out.
Am I not able to edit an app that I created with the public account? If this is not the problem, any ideas what else is going on?
JamesPreston
Hi Kelly,
Would you like another couple to assist your investigations? We have two that have this issue, they are both public, and using the Basic Viewer Template:
http://wcc.maps.arcgis.com/home/item.html?id=5124e3e71a634668a6bc29b3972a7ea8
http://wcc.maps.arcgis.com/home/item.html?id=648d19986c0c4b24b6e9fccb64c6f59c
Cheers
KellyHutchins
Esri Notable Contributor
James Preston​ looks like your apps are failing for the same reason as Carlynne's so try the workaround above and let me know if it works for you. Note that this will remove the configured search and you'll need to reconfigure your search using the template config panel.
