Configure New Map Viewer Popups
3017
04-27-2021 11:40 AM
TonyViveiros2
Hello,
It would seem the new map viewer defaults fields to display in a pop-up alphabetically.  Given the many fields that I want displayed, manually moving these around is a big annoyance.  Is there any way to display pop-up fields in the order they exist within the database using the new map viewer?
Thanks.
Tony
by Anonymous User
Not applicable
Hi Tony,
Did you ever figure this out?  I'm running into the same issue.
Brendan
TonyViveiros2
Hello @Anonymous User,
Unfortunately, I didn't find a solution; however, you may want to consider using Map Viewer Classic.  @AdamMesser1 also posted on this here.
Tony
SeanSummers_CC
It does the same for me. I have to use Classic Viewer. If I open it in the New Map Viewer it rearranges my popups into alphabetical order for whatever reason. Very annoying that it can't honor the actual table structure.
RobinsonJonathanDOIT
Any update on this issue?  We are experiencing the same issue in Portal for ArcGIS Enterprise 10.9.1
ZoevdbAT
I've posted an Idea for this since it doesn't make sense that there's no other way!
Please give the idea a kudo so Esri notices!
