change record limit for Add Data widget?
3728
06-08-2021 07:06 AM
JasonFitzsimmons
We use the Add Data widget in a Web App Builder - based web app (hosted on a local server using the Developer Edition).
It appears there is a 1000 record limit on the layers the user can add in runtime. Is there any way to change this? I don't see anything in the widget settings.  Most of the layers we use have at least 1000 features.
ShelleySchott
@JasonFitzsimmons , This is currently a limitation of the Add Data Widget and is an Enhancement. Below is the enhancement details.
ENH-000123543: Raise the default feature limit or provide an administrator configurable setting that would allow administrators to change the feature number limit of 1000 records when uploading CSV files via Add Data widget.
Shelley Schott
Senior Consultant, Esri Australia
ShelleySchott
Shelley Schott
JasonFitzsimmons
ok, thanks for the info.
mwartman_grey
@ShelleySchott, are there any updates to this enhancement request?
It would be nice to be able to add csv files with >1000 records.
