Attribute tables not opening in Web AppBuilder since 13th April update
1493
04-15-2021 09:06 AM
HelenCooper
I have an application that was built using Web AppBuilder which was working well, but since the update on 13th April it's not been possible to open the attribute tables within the map.
https://mapitout.maps.arcgis.com/apps/webappviewer/index.html?id=eea66ab4caac486b8d354abc077225ee
Is this a buglet that was inadvertently introduced?
Thanks for any help,
Helen
DanPatterson
MVP Esteemed Contributor
There seem to be a number of posts about the April 13th update.
I would contact Tech Support and add your voice to the pile.
For example (although not directly related)
Solved: Help! Since the April AGOL update, our homepage li... - Esri Community
... sort of retired...
HelenCooper
Thanks @DanPatterson , I seem to have resolved it by turning the widget off and on again in the web appbuilder (!), but need to get my clients to clear their cache before it will work (sigh... )
DanPatterson
.... get my clients to clear their cache ...
good luck with that 😊
