ArcGIS Online June 2025 Update Gateway Timeout when trying to login
4194
13
06-26-2025 05:56 AM
DavidColey
MVP Frequent Contributor
Hello - since the ArcGIS Online June 2025 Update last night, I am now getting a Gateway Timeout when trying to login.
Open Data site is really slow, signing into GeoNet really slow.  Seems to be an authentication issue somewhere?
David
RyanUthoff
MVP Regular Contributor
Yep, it's a known issue that Esri is investigating. https://status.arcgis.com/
StuartMoore
i think its related to this: ArcGIS Online Health Dashboard
we're finding the same issues accessing apps and data
Stu
RyanUthoff
David_Brooks
We've just had to down tools and finish for the day. Can't work with AGOL, can't log into Pro. Surveyors unable to sync work. It's a very very poor show from ESRI on upgrade day. How on earth are they not able to stress test this type of issue?
David
..Maps with no limits..
HollyTorpey_LSA
Same boat here... I can't log in to Pro, my colleague somehow got a Pro project to open but no online layers are loading. We have biologists in the field using Field Maps, and I fear I'll be hearing from them soon.
- Holly
RyanWalter
Having the same issues as others. Unable to access AGOL or use ArcPro. Every time I connect it immediately disconnects and hangs all of my projects. Will keep my eye out for when this is fixed.
David_Brooks
Here's a wild idea, roll back the system to yesterday, take the hit from a PR embarrassment perspective, and then properly stress test with a new go-live set for July. You'd get more respect that way I'd imagine.
David
DanielFox1
This issue should now be resolved, please clear your browser cache if needed, if you are still experiencing an issue please log a support ticket with your distributor to investigate further.
RichardHowe
@DanielFox1 - The log in issues are sorted but hosted feature layers are just as bad as yesterday!!
DanielFox1
@RichardHowe apolgises that you still encountering issues, if you are in the EU node please can you log a new support case with your distributor, this will be the best way to get your issue resolved and be kept updated.
