Append data from one hosted feature layer to another
2707
5
03-24-2021 02:39 AM
Labels (2)
GrantBenn1
I am wanting to append data from one hosted feature layer to another, and automate this process using Notebooks. I can manually do this by exporting the source hosted feature layer, downloading and then Updating the target hosted feature layer. However, this seems to be a very long way around and overly complicated if one is looking to automate the process.
Grant
JakeSkinner
Esri Esteemed Contributor
Hi @GrantBenn1 ,
You could simply use the Append tool in ArcGIS Pro.  It accepts feature services as if they were feature classes.
GrantBenn1
Hi Jake,
Thanks a lot for responding. The users who I want to run the script do not have ArcGIS Pro so they need to be able to run solely in the AGOL notebook environment. I did solve the issue though using the edit_features command.
Grant
José_LuisCc
@JakeSkinner  Using ARCGIS PRO there is another problem, supports attachments up to 7MB
JosephHilliard94
Hi Jake, do you have an answer to this? I need to do this via ArcGIS Online also rather than Pro.
JakeSkinner
@JosephHilliard94 you could use AGOL Notebook Server.  Take a look at the following document.  It has similar functionality to what you're trying to do, and could be revamped to run in Notebook Server.
