Adding related table to ArcGIS Online feature layer
86876
73
01-08-2019 10:26 AM
EricGardecki1
I'm trying to figure out how to add a relationship class (related table one-to-many) to a feature layer within AGOL. I do not have ArcGIS Desktop or Server (do have QGIS but I don't think that will help here).
The only info I was able to find led me to believe that it may be possible by editing the service definition JSON but I can't find any reference as to how to edit it to make it work.
What are my options here?
Also, is viewing/editing/adding to related tables supported in AGOL web apps yet (not just Collector)?
Thanks!!
EricGardecki1
KhaledHassen
Eric,
I see the GUID field is defined as editable=false
 {       "name" : "reference",        "type" : "esriFieldTypeGUID",        "alias" : "reference",        "sqlType" : "sqlTypeOther",        "length" : 38,        "nullable" : false,        "editable" : false,        "domain" : null,        "defaultValue" : null     },
The guid field needs to be editable. The Globald is the only field that needs to have editable=false.
Sorry we do not have a way to change this property from the admin API. You can drop the relatiohship and the guid column and repeat the process . Will be good to start from scratch just to be sure all are good.
Khaled
EricGardecki1
That worked.  I recreated everything and can add the related records.  I am unable to see the related records through the default popup and such but I can through the data table and via custom arcade based popup.
Still can't export as FGDB but I really don't have a reason too so I suppose it doesn't matter.
Thanks for all your help.
EricGardecki1
khaled hassan‌ you mentioned "dropping" a relationship above.  Can you tell me how this is done?  I can't seem to figure it out.
I ran into some sort of issue with the related table so i want to reverse everything.  I need to remove the relationship and then remove the related table and start over.  I do not want to have to delete the service entirely and start over completely.
I tried using the updateDefinition and deleteFromDefinition and everything I do just seems to stay there anyway after submitting.
What I tried to do was when adding the related table, include the fields for edit/create/editor/creator.  But doing so seems to have messed things up so I want to revert back to a more simple related table.  Unless you can tell me what I may have messed up with adding those fields?  Here is what I used:
"layers" : [
"name" : "Maintenance",
"type" : "Table",
"editFieldsInfo" : {
"creationDateField" : "CreationDate",
"creatorField" : "Creator",
"editDateField" : "EditDate",
"editorField" : "Editor"
"editingInfo" : {
"lastEditDate" : " "
"fields" : [
"nullable" : false,
"editable" : true,
"length" : 38,
"visible" : true,
"domain" : null,
"name" : "MaintDate",
"type" : "esriFieldTypeDate",
"alias" : "Maintenance Date",
"length" : 8,
"nullable" : true,
"editable" : true,
"domain" : null,
"name" : "MaintType",
"type" : "esriFieldTypeString",
"actualType" : "nvarchar",
"alias" : "Maintenance Type",
"sqlType" : "sqlTypeNVarchar",
"length" : 256,
"nullable" : true,
"editable" : true,
"visible" : true,
"domain" : null,
"name" : "Notes",
"alias" : "Notes",
"length" : 256,
"nullable" : true,
"editable" : true,
"visible" : true,
"domain" : null,
"name" : "CreationDate",
"alias" : "CreationDate",
"length" : 8,
"nullable" : true,
"editable" : false,
"domain" : null,
"name" : "Creator",
"alias" : "Creator",
"length" : 50,
"nullable" : true,
"editable" : false,
"domain" : null,
"name" : "EditDate",
"alias" : "EditDate",
"length" : 8,
"nullable" : true,
"editable" : false,
"domain" : null,
"name" : "Editor",
"alias" : "Editor",
"length" : 50,
"nullable" : true,
"editable" : false,
"domain" : null,
"name" : "FID",
"type" : "esriFieldTypeInteger",
"actualType" : "int",
"alias" : "FID",
"sqlType" : "sqlTypeInteger",
"length" : 4,
"nullable" : false,
"editable" : false,
"domain" : null,
Can you assist?
Thanks!
KhaledHassen
Did you try deleting the table directly? deleting the table will also dropping any relationship it has with other layers.
Khaled
EricGardecki1
via deleteFromDefinition?
Last time I tried I ended up with 2 relationships so I thought there was a better way but I can try again.
Do you see anything wrong with my JSON for adding the related table with editing tracking?  I don't know why the relationship isn't working and that is the only thing I have changed this time around.  I really wanted it to auto-create the date of edit so I didn't need the users to have to enter the date manually.
KhaledHassen
Yes on the service (not the layer) deleteFromDefinition.
You will need to pass something like:
   "layers" : [
      "id" : <tableId>
BTW: Editor tracking is added at the service level. When you create a feature service, you will need to specify:
    "editorTracking" : {
      "enableEditorTracking"  : true
So editor tracking it is a system property on the service and you do not really  need to add anything on the layer for edit fields as long as you enable this on the service.
Khaled
EricGardecki1
I removed the layer and readded.  I'm still having my same issue.
When I try to add a related record in a web app, the window just seems to hang and I can't hit the "+".
In Collector, when I try to add a new record to related table, it simply says "Update Failed"  "Updates could not be sent".
Any suggestions?
KhaledHassen
Can you share the service url? I can take a look.
