Add GUID field to existing AGOL Survey123 feature layer — Field not auto-populating?
448
11
a week ago
Bud
Legendary Contributor
I have a Survey123 feature layer that was created using the Survey123 wizard.
I need a custom auto-populated unique ID field, so I've added a GUID field using AGOL > Data > Fields. This is the resulting field:
Problem:
When I create new features in an Experience Builder app using the Editor widget, the new GUID field is not being populated. Why isn't it being populated?
Use Case:
Auto-populate unique ID field in hosted feature layer (common ID between copy/pasted features in ExB...
I need a custom unique ID field so the values will be copy/pasted into a new feature in a different feature layer. The ExB editor widget matches fields in the source layer (the Survey123 layer) with fields in the destination layer, where the field names are an exact match. I can't use the OOTB OBJECTID or GlobalID fields from the source layer, because the destination feature will get new values in those fields, not the values from the source feature.
Bud
Auto-populated GUIDs via NEWID() function — In web map, display a more intuitive value in the Edit tool
https://community.esri.com/t5/arcgis-online-ideas/auto-populated-guids-via-newid-function-in-web-map...
Bud
Based on comments in Support for Attribute rules in ArcGIS Online:
@Allison_Hockey  @IvanKozoletov1  @PaulBarr  @RichardLittlefield  @KevinMayall  @CalvinHarmin  @LeviCecil might find this post interesting.
You might also like Expression field in view using AGOL UI.
Also:
Since you mentioned Survey123 if you are using Connect, there is uuid() function you can use to populate a unique id
https://community.esri.com/t5/arcgis-online-questions/auto-populate-unique-id-field-in-hosted-featur...
And Understanding Relationship Classes in ArcGIS Online Hosted Feature Services
