Show Pop-ups in Attribute order rather than Alphabetical by Default
13066
41
02-18-2021 03:51 PM
Status: Open
JamieLambert
Hi All,
Hopefully this isn't something I've just missed!
It seems the default view for pop-ups is alphabetical rather than attribute order. To me it makes more sense to have the default order as attribute order - I'm sure most people creating features apply a logical approach to table design - and having to completely reorganise the pop-up is frustrating. Can the default order be changed to attribute order? Thanks,
Jamie
41 Comments
LJackson29
@SunshineCoastCouncil  I am not sure what the setting options are for a custom web app, but if you use Experience Builder, the map should maintain the pop-up you created in the Map Viewer (you will need to turn on the pop-ups in the Map widget settings). You can also add a Feature Info widget which can either use the pop-up you created in map viewer or you can customize the feature info widget to show the fields you want in whatever order you want. I hope this helps.
