Your Ideas in Map Viewer Beta
5001
25
11-20-2019 07:51 AM
by Anonymous User
Not applicable
6 25 5,001
You may have heard that Map Viewer Beta released on November 19! This post showcases some of the great ideas that were included in the initial release. Many more ideas will be implemented in future releases - functionality in the pipeline is listed on the Map Viewer Beta Road Map
The following ideas have been marked as implemented:
1. Show attachments in ArcGIS Online pop-up window
It is now out-of-the-box functionality to display photo attachments directly in pop-ups. Attachments can be displayed as large images in the pop-up as a gallery or included as links with a small preview in list format. When creating an app from the map, choose an app built on the 4.x ArcGIS API for JavaScript to see gallery-style pop-ups.
2. Improve available default Map Layouts for Printing in ArcGIS Online
There are now more options when printing a Web Map. Among these are more default layouts and output format choices, as well as the capability of setting a precise scale and DPI when printing.
GIF of printing improvements in Map Viewer Beta
3. Auto-size/Customize width of ArcGIS.com map popups
Pop-ups now automatically resize themselves to fit the content and map where they are displayed. No longer are lengthy field aliases truncated and data hidden in pop-up windows.
4. Dot Density Map in AGOL
It is now possible to compare raw-value attributes with this popular cartographic style. In a Dot Density Map, each dot represents the same quantity of your data (418 people, in the below example), and different color dots represent different categories. It's a compelling way to visualize data for geographically distinct areas such as counties.
Dot density map example
5. Map Rotation In ArcGIS Online
The functionality now exists to rotate any direction from north. In Map Viewer Beta, just right click on the map and move the mouse. This will rotate the map. Use this to make streets appear perpendicular to the web map or app layout, no matter what direction they are facing (cough cough Toronto).
Web Map Rotation
6. Layer Order - ArcGIS Online
You now have the freedom to order layers in your map any way you want, regardless of their type. Map Image Layers, Tile Layers, and Feature Collections may now be moved on top of Feature Layers and vice versa.
7. Reorder bookmarks in arcgis.com map viewer
Functionality has been added to change the order of bookmarks in the redesigned bookmarks panel. Just drag and drop the bookmarks in the order you want your audience to see them.
reordering bookmarks
The following idea has been marked as partially implemented:
1. Movable popup window in ArcGis Online
Sometimes pop-ups are in the way of features that should be visible. With Map Viewer Beta, you can now dock the pop-up to the side of the map, out of the way of features. When testing this feature out, we found that there was no good place to move a pop-up to, so our design now implements a consistent placement of the pop-up away from the initial feature. Also, the browser remembers if you docked the pop up and will reopen the maps with the pop-up in the same location for the same map when opened in the future.
docking a pop up
Notable idea that didn't make it into the first release:
1. Group layers for ArcGIS online
We wanted to mention this as it is the most up-voted idea in all of ArcGIS Ideas. It may seem like an elephant in the blog as this isn’t on the initial release; this functionality is in the pipeline for the first half of 2020, but has some compatibility issues with existing apps. We are working hard to provide support for this across the ArcGIS Platform and will make it available once it can be consumed by ArcGIS Apps.
To learn more about Map Viewer Beta be sure to check out the GeoNet space. There are tutorials, a road map of what's coming, a functionality matrix, and forums to discuss the product and share your opinion. Thank you for your engagement and valuable feedback provided to ArcGIS Ideas. Please keep letting us know your ideas, and we hope you like the first release of Map Viewer Beta!
25 Comments
simoxu
by MVP Regular Contributor
Good stuff.
But one thing is missing in the new map viewer, and it has been working in the current map view: showing related tables. hope this function will be put back in the final release.
ArtMohr
This is a really cool and useful update.  Lots of new features that will be very useful.  However, if there is one thing that could be improved that I believe would offer great value is to improve your print options.  I do like what you have done so far - features for printing the map are vastly improved, but I would like to have the ability to center the map within a print window so that I can control what is printed rather than guessing.  Can't you create a print window that allows me to move/zoom the map to the area I want printed, prior to printing?  Similar to the feature within ArcGIS Pro?  Currently you are forcing me to guess what will be printed and more times than not I have to fiddle with the map view many times to get it right.  Thanks!
by Anonymous User
Not applicable
Hi Art,
Glad to hear you like the update and thanks for the feedback. I think there is an existing idea for the functionality you are requesting, I would recommend going in and up-voting this:
Best,
-Peter
by Anonymous User
Not applicable
Hi Simo,
Thanks for the comment. This is coming in a future release. This blog has some further information on the pop-up road map: Fast, flexible and fun: The new pop-up experience in the next generation Map Viewer Beta
-Peter
BrianE1
Would be nice to have the ability to add the attachment at top of pop-out. Also, user should have the option to exclude the text "Attachment" in the pop-up. Doesn't seem necessary.
by Anonymous User
Not applicable
Hi Brian,
Thanks for the comment. You should be able to drag the Attachments element on top of the Attributes or Text elements in the Configure Pop-up side panel. Is this the functionality you are looking for or is it slightly different? I've brought up the feedback about excluding the word Attachment from the pop-up and will follow up here.
Hope that helps,
-Peter
by Anonymous User
Not applicable
I absolutely love this new Map Viewer. But is it just me being the clumsy noob everytime something new is updated in, or is the 'Open Attribute Table' not there? I mean, there are times when I have to edit some of the attribute values of the features online and I can't seem to find a way to access the attribute table of the layer. It's a little frustrating. Is this function no longer there?
Azalea
by Anonymous User
Not applicable
Hi Azalea,
Happy to hear that you like Map Viewer Beta! It isn't just you - this feature is not in Map Viewer Beta right now. Accessing a layer's attribute table is on the Road Map for the first half of 2020.
https://community.esri.com/docs/DOC-14311
Hope that helps,
-Peter
by Anonymous User
Not applicable
Awesome! Thanks for sharing the roadmap. Can't wait to deploy its usage to my colleagues!
Thanks Peter!
by Anonymous User
Not applicable
Happy to help out!
You might have seen this GeoNet space - the Map Viewer Beta team is active on here if you or your team has any feedback/questions while testing things out:
https://community.esri.com/community/arcgis-online-map-viewer-beta
-Peter
ArtMohr
Hi Peter –
Yes. I’ve already posted a comment to the team as well.
Art
by Anonymous User
Not applicable
Excellent stuff! Two comments:  1) I still recommend allowing dragging popups. (example: www.sagis.org/map) because that is an expected behavior. Also, if the anchor/leader line stretched while dragging, it gives a better screenshot because it more clearly shows what feature it is referencing than a simple halo. This is a big step forward but I still would propose draggable and resizable windows. Dragging and a resizing gripper in the lower right are universal user interface convention for windowed interfaces.
2) Grouping of layers and reordering: does this work with map image sublayers? That is 99% of the actual feature that people are looking for. Even once we finally update our server to take advantage of feature layers that can perform, it will be a while before agencies do. Map image layers aka dynamic map services are not going away for several years. Map image sublayers need ability to group and reorder. This is worth development time and is my number one request.
This is off to a great start! I am glad it is being released in phases, and it is a public beta. Definitely more efficient.
NongHong
Great stuff here.
A major issue I'd like to see addressed is the severe lack of polyline pattern options, as well as fill options for polygons. There appear to only be about 8 or so polyline pattern options, and all of them look extremely similar (they are just variations of hash marks). ArcMap provides dozens of options for polyline patterns and polygon fill options. A lot of times, one can't rely solely on just a different color in order to best represent data. This issue extremely limits how one can visually represent/differentiate data on AGOL.
KassandraRodriguez
Please let us drag the pop-ups
by Anonymous User
Not applicable
Hi Kevin,
Thanks for the feedback and glad you think it's off to a great start!
1. Other customers have similar feedback on this one as well: Cannot resize or move a popup still?
I appreciate the specific description of UI expectations and use case. Would you want the location of the pop-up to be saved for users when they re-open the map? Do you envision a selection color along with the leader line when dragging/resizing the pop-up?
2. For Map Image Layers with dynamic layers enabled, grouping sub layers would be possible. Re-ordering is possible in the existing Map Viewer for dynamic map services so this behavior should be the same. Would you want to see Map Image Layers honor existing group layers configured in ArcGIS Pro before publish, and also enable the Web Map user to alter those groups and re-group/re-order?
-Peter
by Anonymous User
Not applicable
Peter thank you for writing!  And yes it is off to a great start and I appreciate Kelly Gerrow‌ publishing the roadmap.
Popups - Hm I don't think that would be too important to remember the location. In fact it may even be counterintuitive. I would simply say that users almost always expect to be able to drag the popup, as they have since ten years ago. Now of course they can with the clever dojo trick. However, a leader line would both make for better screenshots as well as more readily indicate what feature the popup applies to.
I would also suggest making the halo color and symbology for a clicked-on feature customizable in the webmap. It is possible in the API but it would be convenient to do it from graphical interface in the webmap with a color picker and symbology chooser, for feature highlighting.  And now I see what you were asking, whether it should have a leader line instead of a highlight color.  I either want both, or maybe sometimes just the halo like the way it currently is. I don't think I'd want a leader line without shading/halo, but I could see sometimes wanting only shading/halo as currently. But usually I think I'd want both. It's intuitive.
Map Image Layers - sweet.  Yes since it is really just a matter of the the interface in the DOM, i.e. a button to toggle visibility, it should be possible. At the conferences they said it was not coming to map image sublayers though. I think perhaps because AGOL forces map image sublayers to render as featureLayers.  It is the most important type of layer to group (map image sublayers) and also it is technically quiet easy. I used to do it in my own native API app with the AGS JS TOC 3.x custom widget.  While we are on this, I will again suggest that checkboxes have partial state. If only some of the layers in a group are on it should have a partial checkbox. This applies to all Esri products, Pro, Desktop, APIs, and apps.  Only Esri Earth does this correctly. Also, if you turn a layer on, at least optionally, it should have ability to force its parent to turn on. This is actually very important. users find it confusing when they turn a sublayer on and it doesn't become visible because the group above does not turn on. And the partial checkbox thing gets to this... because one way I work around this issue, is to have all Groups on. But... if some but not all sublayers are on, users may be decieved because the checkbox is on, not only partially filled in. So they don't know to expand. It's better than nothing but still an issue.
Regarding grouping - I just want to be able to group layers in the webmap. And they may be coming from various different federal agencies from ArcGIS Servers from versions stretching back a few years and so hopefully grouping map image sublayers will not require Pro or Server 10.8 etc.
Lastly regarding AGOL rending map image sublayers as featurelayers that is actually very important. I hope that the new AGOL can render map image sublayers as map image layers. Our Open Data has hundreds of sublayers spread across about a dozen services. Rendering large layers as featureLayers is so slow it does not work, and also hits the max record limit. The only way around this would be to publish 600 services, one service for each layer. Not feasible. In the long term, featureLayers with quantization wlil be the answer. But I still hope the new AGOL might be able to render a map image sublayer as a true map image layer (dynamic service). Because sometimes you want to bring in one sublayer from a map image service from, for example, a federal agency server. And when it comes in as a featureLayer it's just too slow to use or hits the max record limit. And while new featureLayer capabilities in 10.8 and beyond Enterprise will be the future it will be at least a few years until the industry gets up to this version parity.
by Anonymous User
Not applicable
Thanks Kevin MacLeod‌ for the explanation and context here! I will share with Kelly Gerrow‌ and the rest of the team.
Cheers,
-Peter
by Anonymous User
Not applicable
Hi Nong,
Thanks for the feedback. Any specific ones that you would like to see? What type of data do you typically symbolize?
We also have this existing idea for more arrow support and railroad symbology for lines, so I would recommend up-voting if you haven't yet:
Cheers,
-Peter
by Anonymous User
Not applicable
Wow well all that would be super cool. I was just thinking basic color picker with transparency level and some basic line symbology like thickness and dash level. This is for highlighting a feature by clicking on it, for the popup. So it probably wouldn't get any more advanced. Although I could see an instance where maybe if a user clicks on a street segment, or a pipeline, there are no arrows showing... until, they click on it, and then it shows the arrow to show the flow?  Just an idea. So sure why not open it up to the full symbology library. But really it would just be nice to have some out-of-the-box customization beyond the cyan blue halo.  (from a GUI in the webmap vs having to custom code to the API)  Thanks for your thoughts Peter!!
by Anonymous User
Not applicable
Hi Kassandra,
Thanks for the feedback. Other customers have also continued to request this as well: Cannot resize or move a popup still?
-What would you want to see to associate the pop-up with the feature? e.g. leader lines, callouts, selection highlight, etc.
-Do you envision this for all users or when authoring the Web Map?
-Would you want to see the pop-up saved in the same location when closing and reopening the Web Map?
Cheers,
-Peter
by Anonymous User
Not applicable
this is mostly important for end users (using an App).  Web maps are primarily for authoring and development. Nevertheless, I imagine if it is in the stack it would be in both places, as like now.
EricFriedlander
Occasional Explorer
I really like the Cluster function, however, when printing a cluster map with a legend, the legend is shown as lines that are labeled "Red_Band_1, Green_Band_2," etc. rather than the cluster symbol and the counts/amounts corresponding to the cluster size, Can this be updated?
by Anonymous User
Not applicable
Hi Eric Friedlander‌ thanks for noting this. It's been logged as an issue and the Dev team is taking a look.
-Peter
by Anonymous User
Not applicable
I would say for the questions: selection as like now is fine, and also add optionally a callout leader line. Remembering location would be neat! Reason being, if you share a link with the WAB Share Widget, it could open up (as it does now) and with the popup in a very specific place. The Share Widget ability to query to a specific feature of a specific layer is actually quite powerful.  But most important is simply being able to move and resize, and have a leader.
RobinDiSalvo1
Wow! love all these great comments and especially the new implemented functions.  Trying to transition to Map Viewer and had a thought.   I just updated all my infographic reports in Business Analytics (from 2020 to 2021) with a simple click here to update button and love how I don't have to recreate/update those infographic reports each year.  Is this possible with maps?  I have a bunch of maps with old population data (2020-2025 Population Maps) or thought it would be cool if the population data could update the same way or do I have to upload the new data into the map as I normally do and remove the old layers?
Robin
