Compatibility Guide for web maps created with Map Viewer (classic) and Map Viewer Beta
Document created by KGerrow-esristaff Employee on Nov 18, 2019Last modified by cwhitmore-esristaff on Jul 13, 2020
Version 13Show Document
  • View in full screen mode
This functionality matrix and compatibility examples outline common workflows and tools that are available in both map viewers. Use this table to identify the expected behavior of specific functionality across Map Viewer (classic) and Map Viewer Beta. Please note the legend below and the compatibility notes about specific workflows and intended behaviors.
Status
Definition
Full Support
Full functionality, including saving, authoring and modifying available.
Example: Adding and symbolizing feature layers in the map viewer beta is supported.
No Support
The capability is not supported in specified version of Map Viewer. There is no authoring support and if a web map is created using the other map viewer, users will not be able to view the capability saved in a Map Viewer (classic) web map.
Example: If a web map is authored in Map Viewer (classic) with table layers, the table layers will not be included in the map when opened in Map Viewer Beta.
Partial: View Only
It is not possible to author web maps with the mentioned capability in Map Viewer Beta. If a web map is created using Map Viewer (classic), users will be able to view the capability.
Example: If a web map containing layers with time animation is authored in Map Viewer (classic)  is opened in Map Viewer Beta, the time animation will be honored and displayed in Map Viewer Beta but cannot be currently be configured.
Partial: Limited Layer Authoring
Layers of specific layer type are partially supported. Layers can be added to the map when authored in Map Viewer (classic) and have transparency and scale range modified in Map Viewer Beta. It is not possible to change symbology or modify pop-ups for these layer types.
Example: A map, created in Map Viewer (classic), with the Living Atlas demographics Map Image layer can be opened in Map Viewer Beta. The scale range and transparency can be modified but there is no ability to modify the symbols or pop-ups.
Category
Functionality Description
Map Viewer Beta
Common workflows
Printing
Full Support
Full Support and more
Standalone tables
Full Support
No Support
Add layer from file
Full Support
No Support
Analysis
Full Support
No Support
Bookmarks
Full Support
Full Support
Map Notes
Full Support
No Support
Add layer from url
Full Support
No Support
Layer Authoring Support for all layer types*
Full Support
Partial: details below*
Sharing from Map
Full Support
Full Support
Editing
Full Support
Full Support
Measure
Full Support
Full Support
Feature Layers
Full Support
Full Support
*Layer Types (Currently supported by classic map viewer)
Map Image Layers
Full Support
(OGC) WMTS, WMS
Full Support
Imagery Layers
Full Support
Tile Layers
Full Support
Vector Tile Layers
Full Support
OGC (WFS)
Full Support
No Support
Table Layers
Full Support
No Support
Feature Collections
Full Support
Partial: View Only
Clustering
Full Support
Full Support
Arcade: Visualizations
Full Support
Full Support
Mapping Capabilities
Heat Mapping
Full Support
Full Support
Smart Mapping: Dot Density
No Support
Full Support
Pop ups: related records
Full Support
Partial: View Only
Smart Mapping: other
Full Support
Full Support
Point Symbols
Full Support
Full Support (selected galleries)
Refresh interval
Full Support
Partial: View Only
Labels including Arcade
Full Support
Full Support
Configure charts in pop ups
Full Support
No Support
Switch between basemaps with different projections
Full Support
Partial support
Time Animation
Full Support
Partial: View Only
Reorder layers regardless of layer type
No Support
Full Support
Filtering
Full Support
Full Support
Interactive Filter/Prompt for values
Full Support
No Support
Arcade authoring for Pop-Ups
Full Support
Full Support
Other
Localized in All Supported Languages
Full Support
No Support (English Only)
Browser: Microsoft Edge
Full Support
Full Support
Mobile Design
Full Support
No Support
Browser: Internet Explorer 11
Full Support
No Support (not on roadmap)
Notes on Forward and Backwards compatibility between Map Viewer (classic) and Map Viewer Beta
In order to create production ready web maps with new and exciting features, maps created in Map Viewer Beta can be opened in Map Viewer (classic) and vice versa. This allows you to have flexibility in how you author your maps. As there is some a difference in functionality available in the two map viewers, we recommend paying attention to a few details, to make sure that new functionality, like dot density maps can be viewed.  There are notifications in both Map Viewer (classic) and Map Viewer Beta to notify you of these circumstances, but this article provides some additional details. In most cases the unsupported content just won’t appear. As a rule of thumb, we recommend using the save as functionality when saving web maps that are authored in both Map Viewer (classic) and Map Viewer Beta. For more information regarding backward compatibility for specific functionality in Map Viewer (classic), see Backward compatibility with Map Viewer (classic).
25 people found this helpful
    Outcomes
