Installing ArcGIS Monitor 2023.3 Fails during Installation.
2391
7
12-21-2023 08:15 PM
MichaelRobb
Honored Contributor
There is a similar thread that seems to echo the same issue.
Windows Installation of ArcGIS Monitor fails before completion.
Calling @ Derek Law !
Similar issues:
https://community.esri.com/t5/arcgis-monitor-questions/arcgis-monitor-2023-1-upgrade-failure-there-i...
Just before this error, there are some CMD windows that 'flash' past...
anyone know the fix?
Attempts:
Ran using elevated permissions - no change
Ran using admin account - no change
Ensure the prior 10.8 install is NOT running in Windows Services  (as per directions by ESRI)
Ensure the Prior MongoDB Install is not running in windows services
Event Logs do not provide any meaningful information.
2 Solutions
MichaelRobb
Honored Contributor
Thanks Derek.  Knowing that this upgrade is not supported works for me.  Ill fully implement a new setup.
Happy holidays.
I will note that the upgrade instructions mentions to not uninstall previous version and that the install will upgrade.  nothing more.
ref https://doc.arcgis.com/en/monitor/latest/install/windows/upgrade-arcgis-monitor.htm
DerekLaw
Esri Esteemed Contributor
FYI @MichaelRobb,
Marking this thread as "answered" because of this reason,
Knowing that this upgrade is not supported: migrating from ArcGIS Monitor 10.8.1 to ArcGIS Monitor 2023
GeoJosh
Hi @MichaelRobb,
If you open Services on the machine where Monitor will be installed, do you see an existing ArcGIS Monitor service?
Josh
MichaelRobb
Honored Contributor
Yes, this is the machine with the ArcGIS Monitor Server.  As per the instructions set by ESRI, I turned 'off' during install.
here is the control panel >> Programs list.
GeoJosh
@MichaelRobb,
Can you please submit a support case for this issue? The solution to this issue depends on a few different environmental factors that should be investigated before proceeding, and an analyst will be able to help determine the best course of action. Shoot me a message with the case number after it is submitted and I will work with the analyst to get the information we need.
Josh
DerekLaw
Hi @MichaelRobb,
In addition to Josh's comments, installing Monitor 2023. on the same machine that has Monitor 10.8.1 installed is not recommended, nor supported. Please see question 5 in the ArcGIS Monitor FAQ.
Hope this helps,
MichaelRobb
Honored Contributor
Happy holidays.
DerekLaw
Hi @MichaelRobb,
Thanks for the status update.
The help documentation you're referring to, is meant for ArcGIS Monitor 2023. So the statement is true, when upgrading from Monitor 2023.0, 2023.1, or 2023.2 - you can directly upgrade to 2023.3. It does not refer to Monitor 10.8.1.
Note we address moving from Monitor 10.8.1 to 2023 in question 6 in the FAQ I mentioned previously.
FYI, the help documentation for ArcGIS Monitor 10.8.1 is separate and can be found here.
Hope this helps and happy holidays,
DerekLaw
FYI @MichaelRobb,
