New Agentic Tools in the Latest Release of ArcGIS Location Platform
ArcGIS Location Platform continues to evolve. The November 2026 release introduces new tools and features that will enable developers to build faster. * MCP support for ArcGIS Location Services now in general availability. * ArcGIS agentic developer toolkit. Read the Blog Article
What Location Services are Available through ArcGIS Location Platform? Mapping, Search, Directions, and More
ArcGIS Location Platform enables developers to add geocoding, places, and data enrichment to your solution without a full GIS deployment. Consumption-based pricing means you only pay for what you use. See which service fits your use case!
Referrer restriction on API key not enforced for VectorTileServer/MapServer tile requests — anyone who copies the key can inflate our usage
We have an API key configured with a referrer restriction (https://*.ourdomain.com/* only), used in a public-facing web map built with MapLibre GL JS. Since the key is attached to tile requests client-side, it's unavoidably visible in the browser's network traffic to anyone who looks. The referrer restriction doesn't seem…
API key with Basemap Styles privilege enabled returns 401 (code 498 "Token Invalid") on Basemap Styles v2
Hi all, I have a free ArcGIS Location Platform account and created a public app developer credential with the Basemap styles service privilege enabled. The API key works for other location services, but every request to Basemap Styles v2 returns HTTP 401 with code 498 - "Token Invalid." Same key, same minute - one works,…
Pick a PaaS that Supports Open Dev
Open-source flexibility or enterprise reliability? You shouldn't have to pick one. Learn how a location PaaS that supports open development gives you both, what to look for in a provider, and why developers switch to ArcGIS Location Platform for location services. Read the Blog
Introducing the New ArcGIS Static Map Service
Introducing the New ArcGIS Static Map Service The ArcGIS Static Maps service enables developers to create and easily embed map images into websites or applications. Customize the style of the map image as well as add points, polygons or routes. Static map images may provide a better user experience where interactive maps…
New MCP Support (beta) in ArcGIS Location Platform
New MCP Support (beta) in ArcGIS Location Platform We are pleased to introduce MCP support in Location Platform! Leverage MCP support to connect location services with agentic AI. MCP support in Location Platform will enable AI agents to discover, invoke, and chain multiple capabilities or location services together to…
Additional Geocoding Attributes
I would like to see additional premium attributes added to the AGOL World Geocoder output. My particular use case is based on adding attributes to correctly match addresses across different lines of business and data vendors. Many companies are utilizing Melissa MAKs and/or Precisely Ids. If you make these additional…
Offline Maps and ArcGIS Location Platform
Hi, I'm using ArcGIS Maps SDK for Kotlin, and my application needs to be partially offline. As a requirement, the offline maps needed to be created ahead of time. But I saw that's possible only with ArcGIS Online or Enterprise account, and I'm using ArcGIS Location Platform, because my users don't need to create an Esri…
API generation for map, api keys are not getting generated
Hi Team In arcgis location platofrm when i tried to create a developer credentials(api key) as per the guide provided by ESRI portals - as expected the api key generation pop up is not even coming - so i cant use it my objective is to use this api key in my SAP FSM application for a basemap provider so initially i signed…
I can´t see "My Portal" in my ArcGIS Location Platform Account
Dear Sirs, I am experiencing problems with the display of "My Portal" in my ArcGIS Location Platform account. I can log in to my account correctly, but when I try to access my content, the page does not load; it remains blank. The following error appears:
Pl. allow esri app free
* For land survey purpose
Can we enable ESRI Location platform to work with modern warehouses?
Can we enable the ESRI Location Platform to work with modern warehouses? Snowflake Databricks with Apche Sedona
ESRI Leaflet with ArcGIS Routing Services
Hello Team, Can I use ESRI Leaflet for commercial use cases? If I include it in my application's Routing functionality, how does it work? Regards, Venkat
ESRI Location Platform Licensing Options
Hi All, How can I get the ESRI Location Platform license without buying ArcGIS Postal or ArcGIS Enterprise? I am exploring the options to buy only Routing features for Supply Chain Management and Fleet Management with optimized routing. Regards, Venkat
How to ensure findAddressCandidates returns deliverable/mailable addresses only
When using the findAddressCandidates API, is there a way to ensure that only addresses deliverable by post are returned? Currently we're setting the category parameter to "subaddress,point address", however for buildings, if input doesn't contain apartment/unit number, the API still returns addresses with only a building…
Is ArcGIS Location Services/Developer Account only for paid users (or is there a free tier as well) ?
The ArcGIS developer accounts is not allowing me to register! I am a new user and was able to create the free public-facing account, but later understood that the developer account has more features. I tried creating the developer account and then was redirected to the Location Services; but even after I verify my email, I…
API Key Usage Alerts
Hi. There are seveal questions on this board regarding alerts for usage of api keys. I'm wondering if this can be scripted? Reading up on the ArcGIS API for Python, at first glance, it looks promising. There is an item.usage method, which accepts time range parameters. The api key is an item. When I tried getting the usage…
How do I access the enhanced contrast basemap via API?
Hello, We are trying to add the enhanced contrast basemap to our application for better accessibility in our maps: https://www.arcgis.com/home/item.html?id=4dd826e83b044acfb519a26fc9b20f80 When trying to access this via rest API, there doesn't appear to be an Enhanced Contrast Basemap style:…
findAddressCandidates with magicKey drops matchId
Hi team, I appreciate that Arcgis now returns matchId in responses. An issue I've found is that when I search with the magicKey specified, I no longer get a matchId. The same request without a magicKey returns a matchId. I have noticed this issue consistently at multiple locations, eg if you search for Eiffel Tower. Please…
GeoEnrichment API setup
Hi. I'm trying to set up the GeoEnrichment API but it's not appearing as an option when I create an API key - so I can't test the service. Is this discontinued? Or blocked to my organization for some reason? Any help would be appreciated - I figured this would be dead simple but now very confused how to get the right…
Seeking Esri Developer Assistance for Accessing Cropland Data Layer (CDL) via API
Hi everyone, I am currently working on a research project that involves ArcGIS Pro and REST APIs, specifically utilizing the Cropland Data Layer (CDL) to analyze agricultural land cover data. CDL provides essential geospatial information on croplands across the U.S., and I need to efficiently retrieve this data for…
/oauth2/token/ suddenly returns 403
I have this webapp that has been doing reverse geolocation for years, get an oauth token and then requesting a reserve-geocode. Now, starting jan 7, the /oauth2/token/ suddenly returns a 403 forbidden (clearly using valid client-id + secret, double triple checked). Now, when running the exact same request (ur, client-id,…
Publish WFS for someone else to consume
I have a Location Platform Account. Is it possible for me to publish a WFS for someone else who has AGOL or Enterprise to consume? If so, what is the workflow? Do I need to embed an API key somehow?
Inquiry about osm/standard base maps
Dear Community, I hope this message finds you well. Could you kindly confirm whether the OSM/Standard Base Maps API can be used in commercial applications? Are there any restrictions or limitations associated with its usage? Additionally, I would appreciate it if you could clarify whether an ArcGIS Online/Premium…
