ControlPointsGeoreference - is maximum of 4 a technical limitation?
909
02-15-2024 08:23 AM
LukeCalladine
Hey all,
I've been using the new MediaLayers to do some simple georeferencing proof of concepts.
Its a really powerful tool but I've found a slight limitations of four control points - where adding a 5th or 6th point would "tighten" the georeferencing in line with expected results. Is there a technical limitation to adding more than four points? Or could this be a potential enhancement for the future?
Cheers,
Luke
Sage_Wall
Hi @LukeCalladine, I'm glad you are finding MediaLayer useful!
Yes there is a limitation of 4 control points due to the perspective transformation we are using to place the media with ControlPointGeoreference. I'd suggest georeferencing the images in Pro and publish them as a service if higher accuracy is needed.
