Application-level Authentication - Proxy is being used for an unsupported service
8604
10
01-11-2016 10:21 AM
ChrisSmith7
Honored Contributor
This is the companion thread to Application-level token authentication
In short, I was successful in creating secured services and authenticating at the application level - somewhat! There's a peculiar behavior I haven't quite nailed-down - maybe someone has experienced this before and has an answer...
When I use a cold session, e.g. after clearing cache and restarting the browser, and then load the secured service through the mapping app, I receive an authentication pop-up (which I am trying to avoid). If I enter the correct credentials, I receive the message:
Unable to access the authentication service.
In the console, the error is reported as a 403:
code: Forbidden,message:"Proxy is being used for an unsupported service: https://mygisserver/arcgis/tokens/"}}"
If I navigate to the REST service in the browser, I am prompted to enter credentials, which authenticates successfully. In the same browser, once the session is established, I can then refresh (ctrl-F5) and see the secured layer without receiving an authentication window. This is the behavior I'm seeking - any user can see the secured service in context of the mapping app, without having to manually enter credentials.
Any ideas as to what would cause this? I am using the proxy from the Esri GitHub. I am also keeping the referrer open-ended for now, until I resolve this issue. I don't believe I'm doing anything crazy - right now, I'm just undergoing some POC testing. Here's the pertinent info on how the proxy config looks:
<ProxyConfig allowedReferers="*"
             mustMatch="true">
   <serverUrls>
      <serverUrl url="https://mygisserver/arcgis/rest/services"
                 matchAll="true"
                 username="user"
                 password="password"/>
  </serverUrls>
Here's how the quick test js looks:
var flTest = new FeatureLayer("https://mygisserver/arcgis/rest/services/base_services/test/MapServer/0", {
  mode: FeatureLayer.MODE_ONDEMAND
var simpleJson = {
  "type": "simple",
  "label": "",
  "description": "",
  "symbol": {
  "color": [0, 0, 255, 191],
  "size": 6,
  "angle": 0,
  "xoffset": 0,
  "yoffset": 0,
  "type": "esriSMS",
  "style": "esriSMSCircle",
  "outline": {
  "color": [0, 0, 128, 255],
  "width": 0,
  "type": "esriSLS",
  "style": "esriSLSSolid"
var rend = new SimpleRenderer(simpleJson);
flTest.setRenderer(rend);
map.addLayer(flTest);
I have confirmed SSL is set-up correctly on the dev server where the mapping app is hosted, as well as on the GIS server. The map service is an xy feature event from an MS SQL Server db slice, if that matters at all.
Thanks!
GirishYadav
If alwaysUseProxy is set to false then set the proxyRules. Add your secured service url to the proxy rules:
esri.urlUtils.addProxyRule({
     proxyUrl : "https://mygisserver/arcgis/rest/services",
     urlPrefix : "https://appserver/proxy/proxy.ashx"
-Girish
GirishYadav
Chris,
In the chrome's Developer Tools go to Network tab and check if the call to feature layer is going through proxy or not? something lilke this:
https://appserver/proxy/proxy.ashx?https://mygisserver/arcgis/rest/services/base_services/test/MapSe...
Also, are you setting the proxy url in esriConfig
esriConfig.defaults.io.proxyUrl = "https://appserver/proxy/proxy.ashx "
-Girish
ChrisSmith7
Honored Contributor
Girish,
According to Fiddler, it's not going through the proxy, which would explain why credentials aren't supplied. I have confirmed, though, the proxy does work, e.g. print. I can see the requests in fiddler through the proxy. I have the proxy URL set as a relative path in the app:
            esri.config.defaults.io.proxyUrl = "../MapApp/Proxy/proxy.ashx";
            esri.config.defaults.io.alwaysUseProxy = false;
            esri.config.defaults.io.useCors = true;
The other config values should already default to the values set - I set them this way for clarity.
GirishYadav
Chris,
esri.config.defaults.io.useCors should be false or the default value "with-credentials" . if its true it will prevent the AJAX calls through proxy.
-Girish
ChrisSmith7
Honored Contributor
Girish,
I tried commenting-out those lines with no luck. I also tried setting it to false and to "with-credentials" - it's still not going through the proxy (I confirmed the JS cache was flushed, so it's using the updated file). Hrmmm...
ChrisSmith7
Honored Contributor
Some more information...
I tried setting alwaysUseProxy to true - I see the requests come through in Fiddler with 200s for all map services, including the secured service; however, the map crashes due to the "Proxy is being used for an unsupported service" error on the base map/canvas. By virtue of this, it seems that the proxy is working, but for whatever reason (maybe config?), it's not properly proxying the secured service when alwaysUseProxy is set to default/false.
Regardless in either case, I can see console messages for
dojo.io.script error Error: Token Required
These go away when I comment-out the logic creating and adding the secured service.
UPDATE:
I tried creating a proxy rule - I see it now being proxied, but the authentication log-in still shows.
GirishYadav
-Girish
ChrisSmith7
Honored Contributor
Girish,
That's what I tried, and I can see the service going through the proxy in Fiddler, but the log-in pop-up still shows. This is true whether or not I have credentials in the proxy config.
ChrisSmith7
Honored Contributor
I thought I had the latest proxy, but it's using 1.0. I'm going to upgrade the proxy and give it a go.If that doesn't work, I'll start debugging the proxy in VS to see if I can find anything and report my findings.
Thanks for helping me!
GirishYadav
Oh, Is there any useful message in the proxy log file?
If you haven't yet enabled it do it as follows:
             mustMatch="true"
logFile="proxylog.txt">
