Zone Lookup Instant App highlight a point in another polygon area
1692
04-16-2024 07:32 AM
TownOfGlastonbury
Hi All,
I am working on a zone lookup instant app, and was wondering if there was a way to highlight a point in another polygon area.
Example for what I’m trying to archive, in my current Web App Builder if you click on a voting district (highlight in blue in the picture) it would highlight the voting polling location in a different polygon (highlight in orange in the picture). See image. In WAB I used the District Lookup widget to get this functionality.
Can this be done in the Zone Lookup Instant App?
Thanks!
@KellyHutchins
BethRomero
This can be done in Zone Lookup if the features are related. The point related to the polygon will be returned in the search results even when it's outside of the zone. It will be highlighted when the app user mouses over the results in the panel.  To set this up, go to full setup mode of the app, and navigate to Zone Lookup > Options. Toggle on "Include related records".
BethRomero
TownOfGlastonbury
That worked, thanks!
JakeRougeaux8
Hi Beth, is "Include related records" no longer an option?  I'm not seeing it.
However, the AGO Assistant fix shared here did the trick.
https://community.esri.com/t5/arcgis-instant-apps-questions/zone-lookup-is-not-working-after-arcgis-...
KellyHutchins
Esri Notable Contributor
No that is not currently available. If the records are related then you could enable the related records option in the config and it would appear when the polygon was clicked and users could select the feature and it would be highlighted. If they aren’t related can you tell me a bit more about how it would work? Is there a field in the voting district that matches the polling location?
