I have used the Zone Lookup template to develop an app to determine if an address is in our service areas. When an address doesn't land in our service areas the text for "Text for no results" shows like it is expected but then never goes away. I can clear the search and run another successful search but that text remains. The home button doesn't remove it. The only method I have found to get it to go away is using Ctrl R. I saw @KellyHutchins help someone with a similar issue (https://community.esri.com/t5/arcgis-instant-apps-questions/zone-lookup-quot-no-results-found-quot-persisting/td-p/1309650)
Any help would be appreciated.
https://rtcgis.rtcsnv.com/portal/apps/instant/lookup/index.html?appid=45768279f016437bb34f86b2365f52c9
Thanks @KellyHutchins for this CSS. Figured I'd pass it along to the community.
#noResults{display:none;}.map-alert #noResults{display:block;}
Hi Todd,
Thanks for reporting us this issue. Can you please re-share your app so we can try reproduce your issue?
Julia
@ToddGurnee is this enterprise or ArcGIS Online? If so which version of enterprise?
This is on Enterprise 11.2
