GeoPlanner and Economic Development Planning
1306
01-30-2017 08:34 AM
RobertStauder
We recently added an Economic Development Planning template to GeoPlanner. This template will help you plan and test scenarios related to the economic impacts of land use transitions. The template has symbols and attributes useful for this type of design work.
It also has a dashboard with 16 different indicators, including jobs capacity, estimated residential units, area of parks, and more. Here's a graphic of the New Single Family Units indicator:
How do you get started with this template? It's easy -
  1. Go to geoplanner.arcgis.com and sign in. (note: You'll need to configure a license in your org)
  2. Click Create New and choose the GeoPlanner Template for Economic Development Planning.
  3. Click Explore > Add Data and add your land use data. If this is your first time using this tool, pick a smaller dataset to help you learn how to work with scenarios.
  4. Click the Scenario dropdown link in the upper left corner of the app and choose Import.
  5. Work through the Import Scenario wizard to add your land use data to a scenario. Open the dashboard and review your indicators!
https://community.esri.com/groups/planning-and-design
