Issue with GIS map on Power BI since the User Types Update
1059
7
07-01-2024 09:39 AM
Labels (3)
PaigeHansen
New Contributor II
Hello,
I signed into Power BI this morning to update June's data. I was prompted to sign into ArcGIS, but when I clicked the sign-in button, an error message appeared. Attached is the screenshot.
This issue happens on my PowerBi Workspace and PowerBi Desktop app.
Everything worked fine on Thursday, so I am assuming the ArcGIS User Types update threw something off. Any ideas on how to fix this or any workaround ideas?
MohamadChibli
Depending on which platform you're accessing the PowerBI, clearing the local storage should fix this issue.
https://doc.arcgis.com/en/microsoft-365/latest/power-bi/clear-browser-local-storage.htm
AlexL_QED
New Contributor II
I have the same issue. I try an login to Powerbi Esri map and when I click to connect nothing happens.
PaigeHansen
New Contributor II
Hi Alex,
I am not sure if you have tried working on your Power Bi workspace. For some reason, I am able to sign in to ArcGIS through the workspace but not the desktop app.
Although I uninstalled and reinstalled Power Bi Desktop so that it is at its most current version, I had no luck with the ArcGis login working.
lah
Experiencing the same issue in Enterprise 11.1
MohamadChibli
PaigeHansen
New Contributor II
Thank you! I followed the Power Bi Desktop instructions and it worked perfectly!
Bloomers3166
New Contributor II
I have the same issues as @AlexL_QED . We have a map powered by ArcGIS for power BI in a published dashboard that worked before the update. After the update, the map access button does nothing when users attempt to click it. The solution of @MohamadChibli works for one day and then when users open the dashboard the next day the button does not work again.
It would be a hassle, to tell users to clear their cookies every day just to access the map. Any thoughts on how to resolve this? Thank you.
ArcGIS Enterprise 11.2
AnthonyLatini
@Bloomers3166 - Hey there! Just posting here since I saw you posted a new topic. I have replied there! Thank you!
ArcGIS GIS in PowerBI sign in button does nothing ... - Esri Community
