Survey123 Create report missing token and managing connections in Power Automate
1485
01-12-2024 04:46 AM
erica_poisson
Hi -
I use Power Automate for a fair bit of automation with Survey123/ArcGIS Online and I am a bit frustrated with the "Create report" action. I've received a message that the flow failed and it seems the ultimate culprit is happening within the "Create report" step of my flow as I receive "Missing parameters required: \"token\"".
Under my Connections options in Power Automate, I can see my Survey123 Connection shows a status of Connected, however the "Create report" action is still failing on credentials. I know that if I edit the flow, I can go to the "Create report" step, click the ... option in the top corner and select +Add new connection, however I also know that will create a new/second Survey123 connection under my list of Connections ,which I really do not want as it becomes a total nightmare to manage connections when you have many of them for the same thing.
Are there any viable workarounds or strategies for this issue? Are there plans to improve the "Create report" action so that it is actually a viable and reliable tool (which IMO it very much is currently not)?
My organization uses ArcGIS Online, so increasing token life doesn't seem to be an option (I can't find it under Organizational settings).
This is cross posted in the Survey123 community as well - here.
Thank you,
Erica
RobertAnderson3
MVP Regular Contributor
As of right now, the token for reports times out every 14 days much like the ArcGIS Online one did previously. We never noticed it before with the Survey123 one because the submission when triggering a flow contained the token.
The solution would be every 14 days to refresh the connection, which can be done by going to Connections, hitting the 3 dots next to the Survey123 connection, and hitting Switch account and then just signing back in with the same credentials. No need to create a new connection each time.
This is mentioned on the video from the live session found here:
https://community.esri.com/t5/arcgis-survey123-videos/survey123-tricks-of-the-trade-live-automate/m-...
I believe they are working on extending this, much like they had to for the ArcGIS Online one previously, though I haven't heard of any updates yet.
RobertAnderson3
jmcewen_ddg
Just been experiencing the SAME issue for the past month after setting up our first custom connector running entirely on Enterprise 11.2. That resolved the token issue perfectly until I can get another flow implemented to refresh the token for me. Am going to try this: https://cloudpointgeo.com/blog/2024/6/27/how-to-avoid-expired-tokens-for-arcgis-connectors-in-power-... and see how it goes. Maybe I'll remember to report back in 14 days.
