View Layers Failing to Load in Field Maps App
5956
10
05-04-2023 11:05 AM
JessicaWay1
I have a project in Field Maps that has 2 View Layers of the same parent layer. Until yesterday, these layers were showing in the map in the Field Maps App and working properly. Now these layers have a "Layers Failed to Load Error".
The rest of the map works fine. These View Layers work fine when the web map and smart form is viewed in a browser window. There are no errors showing in the Field Maps Web Portal. If we add these layers to another map, the same error shows in mobile app. If we add the parent layer to the map, only the parent layer works in the app.
No scheme changes have been made and all sharing permission have been checked.
Has anyone else had this same issue? Why would view layers suddenly stop working in Field Maps?
StefanUseldinger
Are You using ArcGIS Enterprise? If yes, which version?
JessicaWay1
Yes this is in ArcGIS Enterprise 10.8.1. The view layers were stable for months and then suddley stoped working.
StefanUseldinger
Can You post the exact error message (Profile -> Troubleshooting)?
JessicaWay1
The view layers continued to work in desktop/web. This is the only error message we see in mobile.
StefanUseldinger
you can click on the erroneous layer to see the detailed error message or go to "Profile" -> "Troubleshooting"
JessicaWay1
Here is the error message
StefanUseldinger
did you make changes to your domain configuration?
JessicaWay1
No changes had been made recently. And The layer loads fine not in mobile. We have been stumped on why this is happening.
JessicaWay1
@StefanUseldinger
I found this thread in the Collector Community. It appears the issue has been around since 2019. I tried the fixes mentioned but did not have success. https://community.esri.com/t5/arcgis-collector-questions/layer-fails-to-load-in-collector/td-p/68125
We have rebuilt the layers and view layers from scratch and they are currently working.
