Opening Survey123 form in Field Maps (created in 2021 v.3.12) does not work anymore
1148
6
06-25-2024 01:53 PM
KerryKang
Hello,
I built a mobile solution that leverages both Field Maps and Survey123 back in 2021. When users click the asset on the map in Field Maps, a hyper link is created with selected feature's attributes and some real-time calculated values.
I used Classic Map Viewer at that time, and things worked smoothly. Since 2022, it was not in much use, and today I found out that the URL parameter I've created does not work anymore.
Can someone advice where I need to look at it? or perhaps save it as (new) Map Viewer?
Here is a sample url being created on the fly (I replaced parameter values to random text as my data is not public)
arcgis-survey123://?itemID=ItemID&field:Structure_Number=0233&field:Structure_Name=TOWER%20BANK&field:Highway=17&field:Critical_Route=no&field:Asset_Type=BRIDGE&field:Service_Area=A6&center=yvalue, xvlalue&callback=https://fieldmaps.arcgis.app/?
Addition:
With more investigation, I found callback and center worked, but if I include field/value in the URL the survey123 form is not loading.
HannesVogel
Hi @KerryKang , what happens, if you change your link to
https://survey123.arcgis.app/?itemID=ItemID&field:Structure_Number=0233&field:Structure_Name=TOWER%20BANK&field:Highway=17&field:Critical_Route=no&field:Asset_Type=BRIDGE&field:Service_Area=A6&center=yvalue, xvlalue&callback=https%3A%2F%2Ffieldmaps.arcgis.app%2F
Those type of links work in our environment with Field Maps and Survey123.
ChristopherCounsell
MVP Frequent Contributor
The user is having issues with fields and values so manually doin
g this isn't an option.
@KerryKang you should use the UrlEncode function when generating a URL
https://community.esri.com/t5/arcgis-survey123-documents/create-survey123-urls-using-arcade/ta-p/100...
Personally I like this Arcade snippet. Add the {expression/0} as the hyperlink for the pop-up text.
var urlsource = 'arcgis-survey123://?';
var params = {
  // update itemid
  itemID: '<item_id>',
  // update parameters
  "field:field_one":$feature["fieldone_fromthemap"],
  "field:field_two":$feature["fieldtwo_fromthemap"],
  callback:'https://fieldmaps.arcgis.app'
return urlsource + UrlEncode(params);
KerryKang
Thank you for the tip. When I tested it it works as long as I only contained item ID, center values (I hard coded in the example), and callback. Once I included any fields and their values, the survey kept spinning and ended up not opening.
Thank you.
Kerry
ChristopherCounsell
You're missing commas at the end of your lines
KerryKang
oh, that's my bad. I was doing some testing including/excluding certain fields.
With commas between parameters, it still does not load. Do you have other suggestions where I can look at?
Thank you.
Kerry
ChristopherCounsell
Are you using new map viewer? I would recommend you do. Just note that pop-ups no longer drive editability (it's forms) and this could impact edit multiple.
Can you share your latest code?
