Field Maps New Template confusion
4923
9
07-19-2022 08:07 AM
Whereaboutz
UPDATE 3/14/2023
This is now possible in the Field Maps configuration app. https://doc.arcgis.com/en/field-maps/android/help/configure-the-map.htm#ESRI_SECTION1_93E449067ECE49...
However, as far as I know, there is still not a way to update feature templates in the "new" map viewer.  You must use ArcGIS Pro or MapViewer Classic.
ORIGINAL POST
Adding a template to an existing map in Field Maps can be confusing as there are multiple ways to make it look like it should work, but not all actually update into Field Maps.
First how to do it correctly (as of 7/19/2022):
Carefully follow the directions provided in the documentation.
Note, that this only works in Map Viewer Classic and there you have to start editing features, then click Manage at the bottom of the templates list, and create a new template.    If a field has a domain, be sure to enter a valid domain value into the text box as there is no validation.
How NOT to do, but make it look like it should work:
In ANY map editor, add a domain to a field, then use unique symbol renderer to define a symbol based on that domain.  Interestingly, doing this will show features in the template list from the method above but the results will not make it into field maps.
Hopefully this is cleaned up soon so that it works with the new map viewer and either templates are tied to symbology or there is some notification that changes to symbology do not affect edit templates.
LindsayRaabe_FPCWA
MVP Regular Contributor
Hi. Thanks for the detailed information. I've just had a look through the options and it still seems there's no way to add a new feature template in ArcGIS Online. The Field Maps designer only updates the map the layer is loaded into, and not all maps containing that layer. It also doesn't seem to allow the creation of a completely new feature template, just duplicates of existing templates with different field defaults (not a new "category" of feature though added to a Domain after the original layer was published). This seems like a major oversight in the feature service management workflow.
Lindsay Raabe
GIS Officer
Forest Products Commission WA
LindsayRaabe_FPCWA
And to clarify, whilst I have managed to add a new feature template in Map Viewer Classic, that doesn't flow through to the new Map Viewer either.
Lindsay Raabe
GIS Officer
Whereaboutz
That's a great point.  The JS API 4.X based online map viewer simply does not use templates.  They are used in Pro and in Field Maps, but that configuration is stored in a separate portion of the webmap configuration for the newer map viewer. The inconsistency is confusing.  Thank you for digging into this.
LindsayRaabe_FPCWA
That is confusing. As much as I'd like to see it rolled in for consistency, I'd prefer to see a solution in any format (stand-alone?) compared to the current non-solution.
Lindsay Raabe
GIS Officer
JaneDisney
Hi. I have a student running into some issues working in Field Notes with editing the template and adding in location information, do you have any tips on how they can overcome some of these challenges in Field Maps?
LindsayRaabe_FPCWA
Hi @JaneDisney You'll need to post some more info as we can get some context. Screenshots and/or process that they are trying to achieve?
Lindsay Raabe
GIS Officer
LindsayRaabe_FPCWA
Idea posted here to get this resolved! Include ability to update feature service Feature ... - Esri Community
Lindsay Raabe
GIS Officer
JeremyUmlauf
I used to use the map viewer classic way to change the symbology and it was terrible. however now after our new update to enterprise 11.4 we no longer can do this. Does anyone know if they have figured this simple problem out yet?
EmilyGeo
Hi all,
Following up: In Spring 2025 we added support for managing templates in Map Viewer in ArcGIS Online. You'll see this in Enterprise 11.5 as well.
You can find the Templates button in the Configure editing menu.
We also added a new feature in both Map Viewer and Field Maps to alert you when the symbology and templates are out of sync. You can click the Update button to automatically sync them. Don't hesitate here- you can always Undo the changes if you need to.
Check out this blog article for more info.
Best, Emily
