Field Maps Locking Up?
1279
04-29-2021 04:34 PM
PeterKT
I have a MMPK that causes Field Maps to lock up on an iPhone.
There is a point dataset (of hydrants) with about 360,000 features only displaying below 1:9K, that if turned on will lock Field Maps when panning.
The same MMPK also crashes ArcGIS Explorer for Windows.
The point dataset is sourced from a local fgdb and is in the same projection as other layers.
Anyone experienced similar?
Peter T, Brisbane
by Anonymous User
Not applicable
Do you see the app crash if you use an MMPK with fewer features (like 100,000 or 50,000)?
PeterKT
I rebuilt the mmpk going back to using the 360,000 points from a SDE and using a different vtpkx for the basemap in the mmpk and it started working.  I did reduce the scale at which the points appear - (1:18K to 1:9K)
The point data is even in a different projection in the SDE!
So I'm not sure what's going on.  Working mmpk has two vtpkx's, two data sources from SDE and two live map services and a locator and it works well.
The original base map vtpkx was a downloaded open street map from ESRI.  The new base map is from another government agency here.
A quirk of mmpk production??
Peter T, Brisbane
