I have a MMPK that causes Field Maps to lock up on an iPhone.
There is a point dataset (of hydrants) with about 360,000 features only displaying below 1:9K, that if turned on will lock Field Maps when panning.
The same MMPK also crashes ArcGIS Explorer for Windows.
The point dataset is sourced from a local fgdb and is in the same projection as other layers.
Anyone experienced similar?
