Field maps - data structure
4603
11
04-14-2023 05:42 PM
AlGrant
I am looking to setup a simple form for people to report locations of invasive plants of which there are about 5 types.
It would seem logical to have a dropdown on the form where you select the plant type from options 1-5 and this will put all the data in one table.
But if then I want to display all locations of plant 1 on a layer - can this be done? Maybe the layer is populate by a select * where type statement?
Is this possible and the best way to set the data up (vs a form for each plant type).
Cheers
Al
ChristopherCounsell
MVP Frequent Contributor
To enable logging, go to the profile in Field Maps, tap Troubleshooting, and enable Logging. Retry the operation that was failing, and the log (visible in the Troubleshooting section) contains details of the failure. This log can be shared with an administrator.
@GlenShepherdwrite a great guide here:
https://community.esri.com/t5/arcgis-field-maps-blog/how-to-export-your-troubleshooting-log-file-fro...
GlenShepherd
@AlGrant
Are you creating the offline map areas on-demand in the mobile app? or have you pre-packaged an offline map area, using the ArcGIS Field Maps Web Designer?
As mentioned by @ChristopherCounsell , it would seem the offline web map might now be misaligned with the schema changes (e.g. domain/choice-list) that have been established.
For troubleshooting purposes, if possible, create a new offline map area (either in the mobile app or through the web designer) and try your editing workflow again.
