Field maps callback URL no longer working in 23.3.0
2270
6
10-26-2023 09:55 PM
ChristopherCounsell
MVP Frequent Contributor
ArcGIS Field Maps 23.3.0 update no longer appears to honor callback URLS?
e.g. launching these two URLs (with an actual survey itemid) from browser or field maps opens the survey, but then on survey submission it'll take the user back to the browser.
https://survey123.arcgis.app?itemID=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx&callback=https://fieldmaps.arcgi...
arcgis-survey123://?itemID=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx&callback=https://fieldmaps.arcgis.app
The same URLs work if an earlier version of Field Maps is installed.
The callback is correct per this documentation:
https://doc.arcgis.com/en/survey123/reference/integratewithotherapps.htm#ESRI_SECTION1_C96F2AA2B3304...
And here:
Field Maps links have the following format: https://fieldmaps.arcgis.app "arcgis-fieldmaps"per
https://community.esri.com/t5/arcgis-survey123-questions/link-to-field-maps-from-s123/td-p/1048785
https://doc.arcgis.com/en/field-maps/latest/prepare-maps/deploy-your-map.htm#ESRI_SECTION1_F7DE2402B...
This may be a bug on release - have a ticket with support - but sharing in case anyone has answers, insight or just to help save some headaches for others who though tehre was an issue with their URLS...
2 Solutions
ZacharySutherby
@ChristopherCounsell
Thank you for confirming, Survey123 is not at fault for the issue the same behavior can be reproduced taking Survey123 out of the equation. Just using https://fieldmaps.arcgis.app?itemID=XXXXXXXXXXXXXXXXXXX reproduces the issue.
How these links work is they require a web server which is then configured for the OS to know what bundle ID to redirect to. For example https://survey123.arcgis.app/ in a web browser will bring you to a Survey123 website which on iOS and Android if the Survey123 field app is installed will redirect to the app. It looks like the web server for Field Maps (https://fieldmaps.arcgis.app/) is down.
@ColinLawrence @KevinBurke
Thank you,
Zach
ColinLawrence
Yes, that is a known issue the Field Maps team is working on. There is a BUG if you want to contact support and to be added: BUG-000162434
Hope to have this resolved soon.
Regards,
Colin
ChristopherCounsell
@Ismael @ZacharySutherby this may be a Survey123 issue on 3.18.145
ZacharySutherby
Hello @ChristopherCounsell
Are you seeing this on iOS, Android, or both?
Thank you,
Zach
ChristopherCounsell
iOS. Reported by field staff and confirmed by me. Latest survey123, older
fieldmaps worked.
Upgraded field maps to latest, issue started.
Android was mentioned but I haven't confirmed it, so not sure
ZacharySutherby
Thank you,
Zach
ChristopherCounsell
Thanks Zachary - appreciate expediting it to the right team
ColinLawrence
Regards,
Colin
