Create a URL to open and update an entity in a field Map IOS
1640
01-10-2024 08:01 PM
HatimKhayroun
Hello, I want to create a link that allows me to open a specific entity on Field Map in order to update it."I've tried the following approach, but it hasn't worked:
arcgis-fieldmaps://?itemID=<my item id>&globalID=<the global id of the entity>."
Can you help me with this? Thank you 🙂
DougBrowning
MVP Esteemed Contributor
There is not one it is still http for some reason.  Instead its like this  - i think the .app part is what launches it
https://fieldmaps.arcgis.app?itemID=a2485f&referenceContext=updateFeature
DougBrowning
HatimKhayroun
thank you very much 🙂 , it works :
https://fieldmaps.arcgis.app/?referenceContext=updateFeature&itemID= <id_item_field_map>&featureSourceURL=<URL_Rest_of_service>/FeatureServer/0&featureID=<Global_id_of_entity>
DougBrowning
