Why point features in a query zoom to location, but polygon features don't?
516
6
02-20-2025 09:15 AM
SimonCrutchley
This is sort of a continuation of this thread (https://community.esri.com/t5/arcgis-enterprise-portal-questions/how-to-get-a-query-result-to-symbol...), so I'm hoping to get an answer. When I run a query on the two layers within my app, I get different responses in the results. In both cases I've set up so that the results show results using the webmap settings, which results in a filmstrip with a thumbnail image and some text. If I click inside any example of one of my point feature results, the map zooms to that location. However, if I try to do the same for the polygon features nothing happens. I can't use the 'Data Actions' option, which might allow this, because it enables Export of data (even when this is unticked) and I cannot allow this.
People were very helpful getting me to be able to change the query result appearance, so I'm hoping you might have an answer here.
Thanks
Laura
by MVP Regular Contributor
I can easily zoom to a result from a query on a polygon feature. There's no need to use the data action; instead, you should use the message action. When the record selection changes, it will automatically zoom to the selected feature when you select that option.
SimonCrutchley
Unfortunately, that's what I've already got, and it works fine for the points (obliques), just not the polygons (verticals).
Any thoughts?
Laura
Have you tried a separate query widget with those configurations for just the polygon layer to see if a configuration issue or something else?
When you click on map, zoom to does the trigger data have all data selected?
SimonCrutchley
No, I hadn't thought of that. I'll give that a go tomorrow as it's home time here in the UK.
Thanks
SimonCrutchley
Okay... I tried setting the verticals as a new query and it worked fine. I then added the obliques and hey presto, that didn't. This suggests that the zoom functionality only works for the first element in the query.
I guess I can do a workaround by creating a button with the two queries in it, so it looks seamless to a user, but it seems rather odd and annoying.
Laura
I can get it to work with both point and polygons within the same query widget though. Definitely weird behavior.
