I notice that the Search widget does not display a pop-up window when addresses are found on the map. When I switch the turn on the Search tool associated with the Map widget, I saw the pop-up window. I have several questions regarding the Search widget/Search tool. Are there any customizations allowed for the Search tool? For example, can I make the pop-up window smaller and give it a different color etc.?
How can I remove the Geocoder from the Search dropdown? I can confirm that it is not in the Utility service:
If the Search tool within the Map Widget is not configurable, can I add the pop-up window to the search results from the Search Widget?
