How to add user manuals and documentation to EB?
693
07-31-2025 06:52 AM
JoseSanchez
Good morning,
How do you add user manuals and documentation to an EB web application?
Thanks
JoseSanchez
Great  job @Brian_McLeer  Thank you for sharing!!!
SteveCole
Honored Contributor
Depending on how complex it is, you could add a popup window with tabs where each tab covers a topic / aspect about the application or just link out to a PDF document where you describe things in as much detail as you'd like.
Brian_McLeer
For our site, I added an embed widget within a widget controller in the footer. I maintain documentation in a separate HTML page.
https://external-gis.gjcity.org/CityMapExternal/
JoseSanchez
Hello again @Brian_McLeer
How did you program:
  • the "Select Map View" drop down box?   Are you using Pages or differnt EB applications?
  • the "Save Instance" button
Brian_McLeer
Thank you for the feedback @JoseSanchez
1. This is a custom widget, but has specific URLs hardcoded so I have not posted it to the custom widget group. It links to separate EB applications. If you would like a copy of the widget, please send me a direct message.
2. The save instance widget was created by @SvenJensen at this post.
    https://community.esri.com/t5/arcgis-experience-builder-ideas/save-instance-widget/idc-p/1611208#M40...
I will also plug that there is a blog that has a library of custom widgets.
https://community.esri.com/t5/experience-builder-tips-and-tricks/a-list-of-custom-widgets/ba-p/13409...
JoseSanchez
