What's Coming in ArcGIS Enterprise 11.3
4522
12
04-11-2024 04:02 PM
Jianxia
A sneak peek into new features in Experience Builder in ArcGIS Enterprise 11.3 planned to be available in late May 2024.
ArcGIS Enterprise 11.3 picks up new features from ArcGIS Experience Builder in ArcGIS Online October 2023 and February 2024 releases. Plus, ability to generate reports in the Print widget. Please check the following blogs for the upcoming new widgets and capabilities in 11.3.
What's New in ArcGIS Experience Builder (October 2023)
What's New in ArcGIS Experience Builder (February 2024
Cheers,
12 Comments
Cory__Williams
New Contributor II
@Jianxia it's great to see the development coming along with XB!
With the New URL Parameters, will it enable us to have a querystring where we can query a specific layer and attribute.
i.e. Layer,Field=Value
PropertyParcels,AssessmentID=1234
Jianxia
@Cory__Williams, you can do so by either constructing Select data URl parameters manually or use the Select widget to help set queries through UI in the builder, then remove the Select widget after copying the URL from the Share widget. However, if you want to pass attributes from another app through URL parameter to automatically select the feature and zoom to it, the ability to zoom to the selected feature is not there yet.
Subu_Swaminathan_GISP
New Contributor III
@Jianxia - when will 'ability to generate reports in the Print widget' come to Experience Builder developer edition?
Jianxia
@Subu_Swaminathan_GISP , the Print widget in the latest developer edition 1.14 can generate reports from the printing service with reports published in ArcGIS Enterprise 11.3.
AKRRMapGuy
New Contributor III
Awesome. Hopefully the Oriented Imagery Widget actually functions at a basic level. The 11.1 to 11.2 change was a DOA showstopping broken mess.
AdamGebhart
Occasional Contributor III
Do you anticipate adding widgets similar to the Enhanced Search or Identify Web AppBuilder widgets created by @RobertScheitlin__GISP?  Our users rely heavily on the kind of functionality in those.
dmoss4real
@Jianxia, in the release for this month will we be able to pass attributes from another app through URL parameter to automatically select the feature and zoom to it. We have 50 customers that need this feature for our new Equity Property Value applications we are rolling out. Thanks.
Jianxia
@AdamGebhart , currently there is no plan to do so.
Jianxia
@dmoss4real you can pass attributes from another app using the Select data URL parameter. However, automatically zoom to it is not yet available. You may use the map scale URL parameter as a workaround if applicable.  Zoom to capability with attributes selection is planned for the October release of ArcGIS Online, picked up by ArcGIS Enterprise later.
AdamGebhart
@JianxiaI'm bummed to hear that but appreciate the response.
Khumalod
I'm very excited about the new capabilities! It sounds so good not to share. I'm looking forward to this exciting environment.
Are there any quick tutorials to assist with migrating from the Web App Builder environment?
Cheers
DK
About the Author
Product Manager for ArcGIS Experience Builder and ArcGIS Web Appbuilder. She likes camping and hiking.
