Happy New Year!
In 2022, Experience Builder team will continue moving widgets over from WAB while support accessibility and add custom widgets in ArcGIS Enterprise. Keep in mind that things are subject to change please.
@Jianxia Im intrigued why Basemap Gallery widget is on the long term and not near/medium term. Is this not a high demand bit of functionality?
@David_Brooks , there is a basemap tool on the Map widget that you can turn on. Understand it reads from your org settings and does not provide a way to configure your own basemaps. Due to limited resources, we try to get as many functions as possible in and hope these map tools could help a bit.
@Marokapara Thanks for sharing your feedback on Edit.
@Jianxia thanks for the quick response. Unfortunately my client's organisation works with multiple coordinate systems and the organisations basemap gallery doesn't work for this reason. Too many greyed out tiles to scroll through.
@Jianxia would really like to see the add data function bumped up to a sooner release too! Specifically shp and kml. Trying to minimise the amount of re-work for users as much as possible.
Would love to see the add data widget bumped up sooner also (similar to that which is found in map viewer). The sketch and print options will be most helpful.
In the meanwhile, is there a way to cobble this together on the user-end using experience builder tools currently available?
Is there a timeline for the edit widget to be complete and taken out of beta stage?
Also, will the edit widget eventually allow batch editing attributes for multiple records instead of only a single record at a time?
@Marokapara , thanks for letting us know. Your request has been added.
@JosephGann__MTA_ , no, there is no easy way to cobble this together. Your request has been added.
@MattBell2 , the Edit widget will be out of beta in the March update next week. The batch attribute editing is under the consideration of JSAPI 4.x. Once it is available in JSAPI, we will include the capability in ExB.
Hi @Jianxia ,
With the feedback you have received here, and the still developing parity between Experience Builder (Js4.x) and WAB(Js 3.x), can esri push the retirement date for JS 3.26 (that aligns with 10.8.1 WAB) back at least another year (to Aug2023) to align better with key missing capabilities you are adding to EB/Js4.x? And then update this page respectively?
https://support.esri.com/en/Products/Developers/web-apis/arcgis-api-for-javascript/3-32#product-support
@JTessier , thanks for the reminder. The JSAPI product page has been updated. Currently JSAPI 3.26 is planned to be retired in August 2023. However, if you are using ArcGIS Enterprise, the WAB product lifecycle falls in the product life cycle of ArcGIS Enterprise.
My ask is Export to GDB somehow. It has been asked for since at least 2017 https://community.esri.com/t5/arcgis-web-appbuilder-ideas/add-quot-export-to-shp-quot-or-quot-export-to-gdb/idc-p/1175032#M2260
CSV is a step backwards. Having to be a publisher just to export data is kinda crazy.
thank you!
@DougBrowning - thank you for sharing. Your request has been added to the backlog.
Hi @Jianxia,
Can you provide an update on the Near Term rollout of Timeslider (Timeslider in WAB)? The limited function of dynamic filter capabilities in EXB has been frustrating, especially compared to the simplicity of the Date Selector in OpsDash for instance.
Thanks in advance.
@mlrtexas , the Timeline widget will be available in the upcoming June update. By then, ExB framework would support the time field so you can chart against the date, for example. I will share what' coming in June soon. Thanks.
@Jianxia - do you have an update to the roadmap for end of year and Q1 2023 ?
I've been wanting something similar to what @RyanBohan suggested with being able to print the pop-up/attribute information and attachments, which would also be similar to what is produced in the Survey123 Report generating. We have field workers who would like to be able to export feature reports of points, but they don't all have AGOL accounts to access the Survey123 Data page. And since we're working with AGOL, we can't create a custom print service (unless I'm mistaken; I read that Enterprise would be needed).
Could there be something that can allow users to print feature attribute reports through Experience Builder? I tried to figure out some possibilities through Dashboards, but EB is what we're hoping to switch over to.
Thanks for your time!
(by the way @RyanBohan , that script you created is awesome!! Thank you for posting that!)
What about geoprocessing widget? any news? we are ending 2022 and I don´t finde any information about this useful functionality.
Are there any other alternative to run a geoprocessing tool inside Exp.B?
@Ohan_GeoDecisions See what's coming in November. Once we finalize the Q1 2023 release plan and 2023 roadmap in December, we will share them with the community.
@Raquel The Geoprocessing widget is planned for 2023. Will share the 2023 roadmap in December with more solid timelines. I am not aware of a way to run it in Experience Builder though.
Thank you @IGTLab_Empress,
For one of the projects, we have some success with the new Sidebar Instant app. The "Print or Export to PDF" (top right) does a pretty good job. (FYI There is a bug submitted for printing in Firefox)
Zoning and Parcel Information Portal (ZAPP) (arcgis.com)
I am sure there is a much better way of writing the arcade, project is still in dev and likely to be in JavaScript as URL returns are not currently possible in arcade. And client-side processing is a lot faster.
I really like how quick Exb can be to configure and hope to a similar "Print or Export to PDF" experience that instant apps offers.
Are there any plans to implement the WAB District Lookup tool within ExB? ... or, is there a way to accomplish similar functionality within ExB already?
Any updates on the roadmap with the geoprocessing widget?
This was a great graphic and update for Experience Builder for 2022. Are you planning on generating a similar post for 2023? It would be very helpful and greatly appreciated.
Thanks.
~Dan
The graphic would be great, but in the meantime, I found this the other day @DJB
https://community.esri.com/t5/arcgis-experience-builder-documents/functionality-matrix-for-web-appbuilder-and/ta-p/1113766
@DJB we are currently working on the 2023 roadmap and plan to share it soon. Also thanks @NT_SRS for sharing the matrix link.
Hi @Jianxia , was a 2023 roadmap ever released? Are there plans to allow arcade expressions to be used within the experience builder widgets?
@BenjaminMittler , 2023 roadmap is now available. Ability to configuring arcade expression in Experience Builder is not on the 2023 road.
Signed in members can post, follow updates, and more. New here? Register a free account.
