Whoops. Deleted cache folders in C:\arcgisserver\directories\arcgiscache\ -now entire server is stopped.
1384
09-12-2022 08:43 AM
skoglor
Hello! We started running out of disk space and we had the bright idea of just dumping some huge folders for ortho test image services and map services that we knew we didn't need any more.  We deleted folders from here. C:\arcgisserver\directories\arcgiscache
Well that broke stuff. The folders we deleted, their services now say "stopping.." and the server itself has a status of stopped.
Any help is appreciated.
George_Thompson
Esri Notable Contributor
Can you not go into the Recycle Bin and restore those folders, then restart the Server service on the machine?
--- George T.
skoglor
Hi George, nope, because I also emptied the bin.. Annnnd this was done right before the backup cycle so I can't retrieve from the vhdx.
I'm wondering if using server manager to change the location of the cache directory could help? It says "Clicking "Apply" will copy all existing configuration files to the new location and restart all of your services." Perhaps that process might cull the deleted ones?
George_Thompson
Yikes!
I am not sure about changing the location of the cache directory. I do not think that will have an impact, since the files are gone and will just copy what is currently there.
Do you have an older backup that could be restored to copy the files from?
May not be the most up to date, but get you part of the way there.
--- George T.
skoglor
Some folders were just too new to be captured by the latest backup unfortunately.
