posted an attachment of the error message..
Hey Julien,
Yes, i was able to figure it out.. with the help of esri phone support. I had a good version of chrome, except i only had IE8, ArcGIS needs 9 or up. So, download IE11, and make sure you have active scripting enabled if youre using server manager in IE.... Internet Options (Security Tab > Custom Level > Scripting > Active Scripting > Enable). Enable it in chrome as well for good measure
Hi Andrew,
Please review these Esri KnowledgeBase articles,
Hope this helps,
I tried both these fixes, but again my problem lies with PublishingToolsEx and not CachingTools
Make sure the ArcGIS Server account and Current User account have permission to read configuration store (config-store) and server directories (directories) folders. Restart ArcGIS Server service (services.msc).
By the way, what version of ArcGIS Server are you using.
Double checked folder permissions and restarted the ArcGIS service. I'm running enterprise 10.5 with ArcGIS and GeoEvent server on a windows 2008 R2 SP1 VM. I have no mention of PublishingToolsEx.GPServer in C:\ArcGISServer\config-store\services\System, but it did create the PublishingToolsEx.GPServer folder in C:\ArcGISServer\directories\arcgisoutput\System
It would be wise to contact your Esri Tech Support representative to check the environment and provide an appropriate solution.
Any news on that ?
I have exactly the same problem.
Also ensure all permissions are correct, the ArcGIS server account should have full control for the c:\arcgisserver folder and the c:\programfiles\arcgis folder
Thank you Andrew !
I had IE8, go on IE11 and now it's working.
Hey Andrew,
Thank you for sharing the solution with us. You may mark your answer as correct so that the thread could be closed.
We have been experiencing this same error/issue.
We are using ArcGIS Server 10.5, trying to install and configure on a Windows 7 desktop.
We have IE version 11.0.9600.18617CO with the Scripting Enabled.
I have also tried using Google Chrome 57.0.2987.110 and Mozilla Firefox
The ArcGIS Server account has permissions to E:\arcgisserver\directories and E:\arcgisserver\config-store
Nothing seems to work.
Hi Troy,
Please contact Esri Tech Support so they can help you investigate the issue.
Hi Derek,
I had already created a ticket with ESRI tech support.
We tried some things, but still couldn't get it to work.
But we just resolved this issue yesterday by instead :
- installing ArcGIS Server 10.4 first.
- Creating the Site in 10.4
- then Upgrading to ArcGIS Server 10.5
This seems to have worked.
Thanks.
