What is the process of reconfiguring Azure IDP when SAML cert is expired/renewed at Azure AD
435
08-31-2022 12:12 AM
Than_HtetAung
Hi All,
Refer to this reference link : https://docs.microsoft.com/en-us/azure/active-directory/saas-apps/arcgisenterprise-tutorial , Azure sso integration with ArcGIS Enterprise. We have done it a few years ago and we got notification from Azure cloud administrator mentioned that they will be going to/require to renew the saml certificate at Azure side. What is the impact and where can I reference the process of require update for this scenario?
Example: Do we just remove and upload back the xml file from the Azure side? I think Azure SSO will be affected by this action because the xml file we uploaded in portal setting page has these certificate value.
Can I get advice for the update process without affecting the existing portal users/group.
The ArcGIS Enterprise version we are using is 10.8.1.
