Web Adaptor and SQL server in cloud architecture
1446
09-15-2020 06:23 AM
MelanieFournier1
i am interested in installing my development environment on the cloud. I saw that I could use the enterprise builder for cloud and I will get all the components on one machine.
I was wondering if someone can recommand the best practices regarding the web adaptors? Do I need to get one for portal and one for server? Or if I have a reverse proxy they are not mandatory?
And if I want to get a database, can I install SQL server express on the same machine, or is that supposed to go on another server? I only deplyed architecture on premises, and cloud is totally new for me.
Thanks.
Mélanie
JoriS
by Esri Alum
Esri Alum
Hi Mélanie,
To answer your question regarding web adaptors please take a look here: https://enterprise.arcgis.com/en/web-adaptor/10.8/install/iis/getting-started-with-the-arcgis-web-ad...
While it is best practice to have one web adaptor for Server and one for Portal, you can certainly utilize one for both.
In addition, here is a brief note on web adaptors and reverse proxies:
If you do not use ArcGIS Web Adaptor in your deployment, ensure that the reverse proxy server's context name only goes one URL level deep. For example, you can have a reverse proxy URL such as https://proxy.domain.com/enterprise, but you cannot have a reverse proxy URL such as https://proxy.domain.com/myorg/enterprise.
Please take a look here for more documentation on reverse proxieshttps://enterprise.arcgis.com/en/web-adaptor/latest/install/iis/using-a-reverse-proxy-server-with-po...
Last, these two links will introduce you to Enterprise in the cloud and Enterprise Databases in the cloud
https://enterprise.arcgis.com/en/cloud/latest/intro/enterprise-in-cloud.htm
https://enterprise.arcgis.com/en/server/latest/cloud/amazon/enterprise-geodatabases-in-sql-server-in...
I hope this helps!
Enterprise Support Analyst
